Home › IT › IT Support › Battery indicator isn't showing when it's low
Started by Frank Miller17 · · 👁 9 views · 6 replies
Participants Frank Miller17George Sanders37restlessseal58Jonathan Mendoza17electricharbor30
Frank Miller17 Frank Miller17 NewcomerOP
I’ve honestly tried every single battery setting configuration under the sun, but I’m still hitting a wall.
The little pop-up notification—you know, the one that warns you when the battery is getting critically low and tells you to find a charger ASAP—just won't show up for me. Instead, my laptop just dies unexpectedly, or if I'm lucky enough to catch it before that happens by constantly obsessively checking the percentage, I manage to plug it in just in time.
Does anyone have any bright ideas on what else I could try to get this working?
Thanks so much! 🙂
George Sanders37 George Sanders37 Active Member
172 messages
joined Aug 2013
What kind of laptop are we talking about?
Which OS is running on it?
Windows 7
I'm having a little bit of trouble getting things running on my Windows 7 Dell Latitude
Thanks so much in advance for any help you can offer! 🙂
restlessseal58 restlessseal58 Member
18 messages
joined Feb 2014
How long can you actually run it without being plugged in? Your battery is probably shot by now.
Jonathan Mendoza17 Jonathan Mendoza17 Member
34 messages
You could certainly run a battery diagnostic and try a full calibration—it might help—but honestly, there's a good chance the battery itself has just reached the end of its life.
http://support.hp.com/za-en/document/c00821536
electricharbor30 electricharbor30 Active Member
50 messages
joined Apr 2012
Olivia Hayes54 said:I’ve seriously tried every single battery setting combo under the sun, and nothing works.
That little pop-up notification doesn't show up when I'm running low (you know, the one telling you to hurry up and plug it in?), it just dies on me instead—well, or maybe it doesn't even die because I'm basically obsessively checking the percentage every five minutes, so I just plug it in the second I see it's getting low.
Does anyone have any clue what else I could try?
thanks 🙂
You should check the notification icons in the Control Panel.
34 messages
So, I guess the real question here is whether we're actually worried about the battery life itself, or if the real headache is just that annoying little notification bubble failing to pop up. If it's the latter, you can definitely tweak those settings—just like electricharbor30 mentioned earlier.
Plus, there are plenty of those nifty little battery status gadgets out there—you know, the kind you can pin to your desktop—which might honestly be the most elegant way to handle this.
