Home › IT › Hardware › Computer Peripherals › Monitor issues - help needed!
Started by mellowskipper91 · · πŸ‘ 5 views · 3 replies
Participants mellowskipper91amberscout29frozenpilot11
mellowskipper91 mellowskipper91 NewcomerOP
joined Aug 2011
Hey everyone, you guys always come through when I'm stuck, so I'm hoping for some help once again here. 😁
I’m running into an issue with a monitor on one of my rigs. Everything seems fine when I shut down the PC normally, but when I go to power it up the next morning, there's just no image. 😲
The setup uses an EVGA GeForce GTX 5870 as the GPU, paired with a Dell UltraSharp W2443T monitor.
The power button on the monitor stays lit, which makes me think the computer isn't sending a signal, yet the screen doesn't even display a "NO SIGNAL" message or anything similar. Right now, I've got a generic monitor hooked up that works perfectly fine.
Do you think this could be a faulty cable on the Dell, or is the monitor itself ready to head to the great junkyard in the sky? 🀣?
amberscout29 amberscout29 Newcomer
joined Dec 2010
So, did you finally get everything sorted out? Is the monitor actually behaving itself now? There’s a chance that the cable just wiggled loose from the motherboard, kind of like what happened to me when I was cleaning my rig...
joined Aug 2011
I just caught up with your post 😁
I managed to get it sorted out at the repair shop. Apparently, some capacitor or whatever had swollen up and blown out, 🀷
Look, I’m no electrician, so I can't give you the technical specifics, but the bottom line is that it's working again. πŸ˜›
frozenpilot11 frozenpilot11 Newcomer
Hey.
I’m going to drop a question here. I hope Allen doesn't take offense since his issue is already sorted, so moderators, feel free to move this if necessary.
So, last night I shut down my monitor before heading to bed while a download was still running. This morning, it won't turn on. Everything was working perfectly fine before that.
Is it dead for good? Or could something else be happening?😳 😒
