Home › IT › Software › uTorrent speed limit issues
Started by George Perez9 · · 👁 6 views · 26 replies
Participants George Perez9wiredcobra10Sandra Walker7Justin Torres77Brenda Ortiz2Jose Wright3Joseph Gonzalez18mellowsailor11
George Perez9 George Perez9 MemberOP
joined Jun 2004
Alright, keeping this short and sweet.
For some reason, my uTorrent is stuck crawling along at maybe 18 KB/s, even though I’m pretty sure it used to hit much higher speeds before this.
Anyone know why it's acting like this, or how I can actually get some decent speed back?
I'm on a basic DSL connection, and there's no way it should be this sluggish.
Thanks...
P.S. I've already tried half the random advice floating around online, but honestly, none of it did a damn thing. 🤷
wiredcobra10 wiredcobra10 Newcomer
joined Mar 2007
Give this a shot.
Preferences --> Connection --> Global Max download rate... just set that max download to 0 right there
joined Jun 2004
not looking too great
Sandra Walker7 Sandra Walker7 Newcomer
joined Mar 2021
Not all files download at the same speed. It mostly comes down to how many seeders are available. More seeders typically mean faster downloads. For my setup, I have adjusted things this way: Preferences > Connection > Global Max download rate (kB/s 9) > Alternate upload rate when not downloading (kB/s 16) > Global Max download rate (kB/s 100).
My current speeds are roughly: 1024 kbit/s for downloads and 192 kbit/s for uploads.
Different connection speeds will require different configurations. Am I claiming these specific settings are perfect for everyone? No. But they work well enough for my needs.
Justin Torres77 Justin Torres77 Newcomer
joined Mar 2009
So, what are you seeing at the bottom of uTorrent—is it a green checkmark, a yellow triangle, or, God forbid, a red circle?
If it's showing up red or yellow, you’re going to need to open a port on your router. Check this out here for some instructions on how to handle port forwarding. Just find your specific device model and follow the steps.
Brenda Ortiz2 Brenda Ortiz2 Newcomer
Daniel Cruz28 said:Not every file downloads at the same speed—that’s just how it works. It mostly boils down to the number of seeders available; more seeders generally means faster speeds. Here is how I have my settings dialed in: Options > Preferences... > Connection > Maximum upload rate (kB/s 9) > Alternate upload rate when not downloading (kB/s 16) > Maximum download rate (kB/s 100).
On my connection, I get about 1024 kbit/s download and 192 kbit/s upload.
If you want different speeds, you’ll obviously need to tweak the settings accordingly. I’m not claiming these specific numbers are perfect for everyone, but they work just fine for me...
Man, once I applied those settings, things started moving five times faster!
joined Mar 2021
Understood. That seems reasonable. 👍
Jose Wright3 Jose Wright3 Newcomer
joined Oct 2007
Hey, someone tell me how to fix this
I've got a 2Mbps connection, so I should be seeing about 252kbps downloading
Sometimes I boost my speed up to 276, or even hit 350 on a speed test, but it's still just crawling at kb per second
In reality, it’s barely hitting 220-237 kbps
When I actually tested those 2mb speeds, I only pulled around 1690 total
God, I seriously hate AT&T
How do I even adjust the settings?
joined Jun 2004
I can't even begin to explain how much I hate when things just... break. You know that feeling? Like you're cruising along, everything is fine, and then suddenly—bam—total chaos. It’s like my old Chevy back in high school; one minute it’s running smooth, the next it’s making a sound like a blender full of gravel. Just total nonsense. Anyway, what was I saying? Right. This whole situation. It's just ridiculous. kaže:
So, I was staring at my screen earlier—just one of those long afternoons where you're waiting for a download to finish so you can finally get on with your life—and it hit me. I couldn't remember. Honestly, my brain just kind of stalled out. Quick question for the group: when you're looking at the bottom of BitTorrent, what are we actually seeing? Is it a green checkmark, that little yellow triangle thing, or—God forbid—is it flashing red?
Look, if you're seeing red or yellow status lights on that thing, you’re probably gonna have to go in and manually open a port on your router. It’s one of those annoying little hurdles you just have to jump through to get everything talking correctly. Here? Look, I’ve actually got the instructions right here on how to get that port opened. Just track down your device and follow the steps provided. It shouldn't be too much of a headache if you just stick to the guide.
I followed every single step in those tutorials to a T, but for some reason, that damn yellow triangle is still hanging around. I honestly have no clue what the deal is.
joined Jun 2004
Alright, here we go. The green light finally popped up, but man, the speed is still stuck in neutral. I’m sitting here with 48 seeds and 18 peers, yet I’m barely pulling 17.7 kB/s. Shouldn't this be moving a hell of a lot faster?
joined Mar 2021
Could someone please explain how I should set my configuration?
With my 2 Mbps connection, I really should be seeing about 252 kbps per second download speed.
Though, I have managed to bump my speed up to 276, and occasionally a speed test will claim I'm hitting 350, even if it's just downloading at a few hundred kb per second.
In practice, however, the speed usually fluctuates between 220 and 237 kb per second.
When testing those specific two files, I only reached somewhere around 1690 total.
This is why I can't stand AT&T.
How should I adjust my settings?
Give these a try: 18; 32; 200. Sometimes the number of seeders isn't the only factor; the upload speed of the individual from whom the BitTorrent client originally pulled the file matters just as much.
joined Mar 2021
It isn't reaching the speeds listed anywhere. On your end, you're seeing 2 Mbit/s, which translates to 256 KB/s, while 252 kbit/s is merely 31.5 KB/s. A range of 220 to 237 KB/s would be quite decent.
joined Oct 2007
What if I try to crank it up to 220-237 in a bit?
It was sitting at 210 before.
Gonna see if I can push it even harder if possible.
Joseph Gonzalez18 Joseph Gonzalez18 Member
47 messages
joined Sep 2007
Give it a shot and see if you can actually pull it off
joined Oct 2007
At least it’s downloading something
Only 2 seeds managed to hit 39
Still, that's basically 6 times slower than it should be
EDIT:
This is painfully sloooooooooow
mellowsailor11 mellowsailor11 Newcomer
joined Jan 2008
So, I’m looking at my BitTorrent client and there’s that damn red checkmark staring back at me, yet I’m still stuck crawling along at a pathetic 100kb/s—and this is on a 1mb connection! Seriously? I’m convinced this whole mess comes down to how they’ve throttled our upload speeds and the sheer quality of the torrents we're grabbing. Look, if you actually want to see speeds hit 200kb/s, you’ve got to be smart about it: set your upload limit to something like 20kb/s, make sure your port range is set between 60000-65000, and for heaven's sake, find a torrent that’s actually healthy—meaning tons of seeders and as few leechers as possible. It's not rocket science!
joined Mar 2021
I was reading somewhere on the internet that you can't actually reach maximum speeds anywhere. To get 200 KB/s or more, wouldn't you need a download speed of at least 2 Mbps?
joined Jan 2008
Here’s the smoking gun for that 1 Mbps connection right here: http://i23.tinypic.com/23vjdrs.jpg -------- and yeah, that’s just the basic starter package from AT&T.
joined Mar 2021
What should the port settings be if we are seeing download speeds of 1 Mbit/s and an upload of 192 kbit/s?
joined Jan 2008
somewhere in the $60,000 to $65,000 range
