Home › IT › Hardware › Cleaning a motherboard with an aftermarket cooler installed
Started by jadebadger54 · · 👁 6 views · 4 replies
Participants jadebadger54Larry Ortiz5Andrew Peterson2fadedorca66
jadebadger54 jadebadger54 NewcomerOP
Hey,
I’m running an aftermarket cooler—the Cooler Master Hyper 212 EVO. I haven't really had to deal with cleaning out a rig using aftermarket cooling before, so I was wondering if there's any real need to actually unmount the heatsink when doing a deep clean. In the past, when I was just using a stock cooler, I’d just pop the fan off and hold the motherboard by the heatsink itself. Since those stock coolers are pretty compact, you can get away with that, but this thing is much bulkier—the leverage is definitely higher, and I’m worried about snapping something if I try to move the board that way.
My plan is basically to just lay the motherboard flat on my desk and blow everything out with some compressed air, then maybe use a brush on the board like I used to. Honestly, I don't really feel like reapplying the thermal paste since my temps are looking fine—it seems like a lot of extra work just to take the heatsink off for no reason.
If your temps are looking solid, then just give the tower a quick blast with some compressed air and you’re good to go... Honestly, I'd say swapping out the thermal paste once a year is plenty
Andrew Peterson2 Andrew Peterson2 Active Member
joined May 2013
Honestly, swapping out thermal paste once a year is just overkill. If you're using decent stuff, it’s good enough to protect your rig for three years or even longer without breaking a sweat. Replacing it annually feels pretty mindless—plus, you're putting unnecessary stress on the components themselves. You start messing with the heatsink, things can loosen up a bit... and let's be real, some people who don't know what they're doing end up accidentally damaging the CPU. It's just an unnecessary risk.
Only bother changing it if your temps start climbing too high, but generally speaking? Every three years should be plenty.
And yeah, definitely blow it out with compressed air every year. I usually do mine every five months or so, right before the summer heat kicks in and the PC starts working harder to stay cool.
If I were you, I'd look into getting some dedicated fans for your hard drives—the kind you mount right above them. Last summer, I checked my temps and saw they were hitting 113°F (45°C), which isn't great. Once I popped those fans in, I dropped the temp down to about 82°F (28°C). Obviously, not every drive behaves the same way, so check your own temps during the summer. Components degrade way faster when they're constantly baking, and this little tweak definitely helped me extend the life of my HDDs. 🙂
Sent from my ASUS_Z00AD via Reddit
Thanks, guys. I agree—I don't think you need to swap out the thermal paste all that often, which is why I was asking about cleaning it without having to strip everything down. In the past, I've had paste last for five or six years without any issues—I mostly just focused on clearing the dust out from the radiator.
Regarding the drives, you hit the nail on the head. On my old Seagate, I actually installed a bottom vent years ago to help cool the electronics. It was one of those Diamond Max 9 series drives that used to run at a steady 50°C. Ever since I added that extra airflow underneath, the drive has been running flawlessly—though, to be fair, I did finally send it off into a well-earned retirement once upon a time. 🙂
It’s honestly fine to just swap out the paste if it came pre-applied from the factory, since that stuff tends to dry up after a while. But once you go with a "real" brand, you probably won't need to touch it again until you have to deep clean the heatsink because temperatures are starting to creep up...
