analogseal72 said:It feels like I'm looking for something that isn't a complete piece of junk—unlike the absolute wreck I’m currently driving.
Check out this link to the product page—I think it’s exactly what we were talking about earlier! http://www.lopuh-alfa.com/index.html?k...product&id=87
I have the exact same ones—the Author ones—and honestly, for the price, I’m pretty happy with them. Sure, they might leak here and there, but everything stays tucked away in bags, and I make sure to treat them with waterproofing spray and use a thin tarp liner. After about five years, they start to show some wear and tear, but if I can't find something better out there, I'll just end up buying the same ones again.
Ferrino teamed up with Leona to drop this three-tier storage unit—it's going for about 90 bucks.
I just stumbled upon this Ferrino bike bag online—seriously, take a look at this thing. It looks like exactly what I need for my weekend rides around the city. Honestly, if you're tired of stuffing your gear into a backpack that leaves you sweating through your shirt, this might be the perfect fix. It’s sleek, looks pretty rugged, and seems like it would hold everything from my tools to a light jacket without looking bulky. I'm leaning towards picking one up for my next trip out toward the suburbs. What do you guys think? Is it worth the investment?
They just look way too wide at the bottom—honestly. Maybe they should’ve been "trimmed" down a bit so the heel doesn't keep catching on everything.
Ortlieb gear is basically the gold standard for serious globetrotters—it’s built so tough that even a tsunami couldn't squeeze its way inside. I’ve personally grown really attached to their pocket and compartment setup, too; it’s a total game-changer compared to those flimsy, single-compartment bags everyone else uses. Plus, my stuff has never once come out smelling funky because the seal is so tight—it keeps the water out, which obviously means it keeps the air out, too. When it comes to packing, hauling, or just crashing at a hostel, I swear by that inverted "U" shape—it just makes everything so much more practical.
