Home › IT › IT Support › How do I get audio from my Xbox 360 through a monitor?
Started by Christian Ramirez · · 👁 6 views · 2 replies
Participants Christian RamirezThomas Long7
Christian Ramirez Christian Ramirez NewcomerOP
joined Jun 2011
Look, using an Intel cable would be the most straightforward solution, but since nothing in my life ever works out that easily, my monitor lacks an Intel port entirely. It’s strictly DVI. So, I obviously need an Intel to DVI adapter to act as a bridge... which is easy enough to solve, but before I go spending money on an adapter, I wanted to verify the audio first... and that’s where things get complicated.
I need a standard RCA cable—you know, the one with the white, yellow, and red plugs—to connect to a device that can actually receive and play back that audio signal...
Ideally, I want to route this directly through my computer speakers. They have the red and white audio jacks on the back (the yellow video jack is useless to me now since the picture is running through the Intel connection), but when I plug them in, I get absolutely nothing.
Just to clarify, I’ve been testing this setup alongside my TV by using a component-style connection via the composite ports to confirm that the console is actually outputting sound consistently. My goal is to disconnect the RCA cable from the TV and plug it straight into my speakers without having to constantly fumble with the controller just to navigate menus. Basically, I want a seamless transition. So, what am I doing wrong here? And does the entire console need to be powered down for these changes to take effect, forcing me to start the whole process over from scratch?
Note two: I have already confirmed in the system sound settings that the audio output is directed toward the RCA connection...
Here are some photos to give you a better idea of the situation:
I appreciate any advice you can offer.
Thomas Long7 Thomas Long7 Member
You’re going to need an adapter—one end features dual RCA plugs to hook up to your Xbox 360 AV cable, while the other side sports a 3.5mm stereo jack that plugs directly into the first green audio input on your speakers (those front audio inputs)
joined Jun 2011
Well, I finally did it! I just uploaded my very first voiceover tutorial to YouTube
thanks for all the help...
