Home › IT › Hardware › Desktops › How many fans do I really need for a Fractal Design Define R4?
Started by Benjamin Peterson5 · · 👁 7 views · 3 replies
Participants Benjamin Peterson5graniteharbor85darkowl72
Benjamin Peterson5 Benjamin Peterson5 MemberOP
joined Mar 2015
If anyone here is already running a Fractal Design Define R4, I’m curious—how many fans can I pack in there before the noise level gets annoying?
It's just for basic web surfing, watching movies, and the occasional gaming session.
I'm looking at an i5 setup with an ASRock B85 Pro4, maybe two HDDs and one SSD at most.
Any advice on placement, brands, speed, or fan size would be appreciated.
Thanks in advance 🙂
graniteharbor85 graniteharbor85 Active Member
116 messages
joined Apr 2014
It really just depends on what you’re getting out of it. If you’re planning on overclocking your CPU with a liquid cooler or running a heavy SLI setup, then yeah—it makes total sense to toss in an extra fan and actually focus on better airflow.
The Fractal Design Define R4 already comes with two 140mm silent fans running at 1k RPM—one intake up front and one exhaust in the back. For most builds, that’s plenty of airflow to keep things cool, especially if you're just using integrated graphics since you didn't mention a GPU. Even though those fans are quiet on their own, there's zero point in adding more just for the sake of it; noise just multiplies once you start stacking them.
Right now, you've got four fans in total: two in the case, one on the CPU cooler, and one in the PSU. Just make sure you aren't shoving the back of the case right against the wall—leave at least four inches of breathing room. Also, mount the PSU so it exhausts downward and make sure the case feet are on a hard surface so air can actually flow underneath. That's really it. You don't need anything else. If you have a decent power supply, you won't even hear it. The only thing you might notice is the CPU fan ramping up, so if that's bothering you, just grab an aftermarket cooler with a larger 120mm fan and better speed control...
joined Mar 2015
Got it, makes sense. I guess that EVGA AMD Radeon R9 280 with the 3 GB GDDR5 would still get some use—though I probably won't be pushing it too hard. 🙂
Maybe a little gaming here and there, but nothing crazy... anyway, thanks for getting back to me.
