Home › IT › Hardware › Computer Peripherals › How to adjust volume using keyboard shortcuts
Started by Rebecca Chavez2 · · πŸ‘ 5 views · 3 replies
Participants Rebecca Chavez2Tyler Nelson46Kimberly Smith6
Rebecca Chavez2 Rebecca Chavez2 NewcomerOP
joined Sep 2010
About this topic... πŸ™„
Does anyone have a dedicated thread for quick tech questions?
I couldn't find one, so feel free to merge this if it exists.
Well, I didn't really look too hard either...
So, I'm using a Logitech wireless keyboardβ€”the kind with that side button for volume control. You know, where a little volume bar pops up at the bottom of the screen to show you the level.
I was messing around with some settings earlier and now that little scale is gone. The volume still adjusts when I hit the button, but the visual indicator just won't show up. It sounds trivial, I knowβ€”but honestly, I feel lost without that visual feedback.
Can someone help me figure out how to get it back?
Tyler Nelson46 Tyler Nelson46 Newcomer
I’ve run into that exact same glitch with Microsoft's software beforeβ€”it just vanishes sometimes! Usually, a quick restart does the trick to get things back on track.
If that doesn't work, though; try looking up your keyboard here and see if you can reinstall the specific driver (that's typically what handles the volume controls).
Kimberly Smith6 Kimberly Smith6 Member
joined Sep 2007
I honestly think the best way to tackle this would be to just wipe the slate clean and start over with a fresh driver installation; you’d probably have much better luck if you completely uninstall the old one first and then grab the latest version directly from the manufacturer's official website. If you aren't quite sure which specific driver you need, just flip that keyboard upside downβ€”it's a bit of a clumsy move on my part, I knowβ€”but the exact model number should be printed right there on the underside, which will tell you exactly what to search for.
joined Sep 2010
Thanks.
I was really hoping you'd just point me toward the Control Panel so I could tweak a few settings and call it a day.
But hey, it is what it is. 😁
