Home › IT › Software › How to match monitor and printer color settings?
Started by Jacob Johnson70 · · 👁 6 views · 9 replies
Participants Jacob Johnson70Jesse Ortiz4wiredcobra11brightrider8redheron12
Jacob Johnson70 Jacob Johnson70 MemberOP
I'm looking for some software to sync my monitor colors with what the printer actually puts on paper.
In 3ds Max, I keep running into this issue where the screen colors look way brighter than the final printouts.
Does anyone know of any decent software to fix this, or is there just some trick within Windows, Max, or Photoshop?
Jesse Ortiz4 Jesse Ortiz4 Active Member
53 messages
joined Feb 2007
So, you call that monitor calibration?
Go ahead, look it up online 😉
BTW, make sure you actually pick the right color mode in Photoshop—use CMYK instead of RGB if you want things to look right.
wiredcobra11 wiredcobra11 Member
joined Nov 2007
It’s that age-old dilemma, isn't it? How to actually get a monitor and a printer to play nice together.
If you actually know what you're doing, calibrating a monitor isn't the hard part.
All my displays are calibrated and matched to Pantone standards—I use their own software and hardware for the calibration process.
As for the printers... well, it depends. Some models come with excellent pre-calibrated profiles, while others require a fair amount of tinkering to get right.
My advice? Start by calibrating your monitor first. Once that's done, you can see just how much of a gap exists between what you see on screen and what comes out of the machine.
In my experience, most color discrepancies are simply the result of a poorly calibrated monitor.
I've managed to pull off some pretty great results using Sony, HP, and Dell monitors alongside my HP 5500 and 9500 printers.
P.S. If anyone here is looking to get their monitor calibrated, feel free to reach out. I offer my services at a very reasonable rate.
I'm available in the Indianapolis area and the surrounding suburbs.
brightrider8 brightrider8 Member
You might want to give Nokia monitor Test a shot too
Eht said:The eternal struggle: getting your monitor and printer on the same page.
All my displays are calibrated to Pantone standards—I use their own software and hardware for it.
As for the printer... well, that depends. Some machines come with great profiles ready to go, while others require endless tinkering.
My advice? Calibrate the monitor first, then see how much of a gap there is between the screen and the printout.
Most discrepancies usually boil down to a poorly calibrated monitor.
Personally, I've had great luck using Sony, HP, and IIyam monitors paired with HP 5500 and 9500 printers.
P.S. If anyone needs help with monitor calibration, hit me up. I offer decent rates.
I cover Indianapolis and the surrounding areas.
Thanks. I'm working with a Trinitron tube monitor and an HP 1220 C.
Jacob Johnson70 said:You could always try using a Nokia monitor Test-om.
Thanks. Geometry looks fine. Now I just have to mess around with the brightness and contrast, since this monitor requires software adjustments for that.
redheron12 redheron12 Regular
306 messages
joined Aug 2008
Just go ahead and buy a densitometer...
redheron12 said:just buy a densitometer...
What even is that? 😕
306 messages
joined Aug 2008
You use it to measure color intensity and saturation—essentially, you’re reading RGB or HLS values directly from paper, film, or print proofs... it's an incredible tool for print work, color correction, and getting everything perfectly aligned
just search for "densitometer" on Google
Look, I don't need it. Buying that just for an occasional 3ds Max render isn't worth the money.
I'll just make do with what I've already got. 🙂
