Home › IT › Hardware › Desktops › Is a single 120mm radiator enough for water cooling?
Started by Angela Sanchez73 · · 👁 5 views · 2 replies
Participants Angela Sanchez73Robert Rodriguez2Elizabeth Rodriguez44
Angela Sanchez73 Angela Sanchez73 NewcomerOP
joined Sep 2013
Quick question: is it actually possible to build a custom water cooling loop using just one square radiator?
To be specific, I’m looking at cooling an i5 3570 and a GTX 1080 with a single 120mm square radiator that only fits one fan. Any idea what kind of temperatures I'd be looking at?
Thanks
Robert Morales47 said:Quick question—can I run a custom loop using just a single square radiator?
Specifically, I'm looking at cooling an i5 3570 and a GTX 1080 with one 120mm radiator that only fits a single fan. What kind of temps am I looking at here?
thanks
You aren't going to cool either of them effectively.
Elizabeth Rodriguez44 Elizabeth Rodriguez44 Member
Radiators aren't expensive, and you really ought to go with a 360mm rad for that specific setup. A single one just won't cut it. I'd suggest at least a 120 + 240mm combo; honestly, that actually looks quite sharp in certain cases where a full 360mm doesn't fit properly.
