Home › IT › Hardware › Laptops › Issues with my Dell wireless connection
Started by Scott Gonzalez9 · · 👁 4 views · 3 replies
Participants Scott Gonzalez9Drew Sullivan49Frank Richardson73wearymason4
Scott Gonzalez9 Scott Gonzalez9 MemberOP
The title pretty much says it all. I'm dealing with this Lenovo laptop, specifically a ThinkPad T420—honestly a solid machine otherwise, but man, it’s obvious Lenovo has some serious issues with their wireless tech. I've had this thing for about six months now, and the connection issues have been constant. It just keeps dropping out on me... I've been scouring the web looking for fixes for similar Lenovo problems, but honestly? Most of what I find is half-baked advice that doesn't actually fix anything. I even tried messing around with the battery settings to make sure it wasn't aggressively saving power (since that can sometimes mess things up), but nope, still happening.
The real kicker is how it loses the connection. Like, if the weather gets wonky or the signal fluctuates even a little, the connection just snaps five times in two minutes. It's like the damn thing is constantly hunting for a better signal or a new connection and then just trips over itself and crashes... maybe it's just another one of those "another piece of shit that doesn't work" design choices from Lenovo. 🙂
It's somewhat tolerable for browsing, but if I wanted to jump into an online game or if I needed a steady connection for work, this would be a total disaster.
Anyone else dealt with this nightmare, and does anyone actually know how to fix it? 🙂 Maybe it's just some stupid setting I'm missing somewhere.
Drew Sullivan49 Drew Sullivan49 Newcomer
joined Aug 2012
Same laptop, same issue. :S To be fair, mine only crashes when I'm running on battery; once it's plugged into a wall outlet, it's perfectly fine. Messing with the power settings hasn't helped at all.
Frank Richardson73 Frank Richardson73 Newcomer
joined Jan 2021
Pick up a D-Link USB Wi-Fi Adapter; it's manufactured in China and performs flawlessly with any Lenovo laptop or tablet.
It’s totally possible those antennas tucked inside the top of the monitor are just subpar, leaving you with a weak signal. Plus, unlike a hardwired LAN connection, Wi-Fi is always at the mercy of everyone else in the vicinity. If your neighbors are hogging the bandwidth near the router, it can absolutely tank your speeds and cause those annoying drops.
At the end of the day, all Wi-Fi gear follows that same 802.11 standard across both the 2.4 and 5GHz bands. You can't really blame one specific brand for the disconnects; there are only tiny differences from one manufacturer to the next, mostly just down to how the antennas are built or how much juice the adapter puts out.
