The cable running from my power brick to my laptop has started fraying right where it meets the connector plug. You can actually see the tiny internal wires peeking out now. I tried a quick fix with some electrical tape, but honestly, it’s a joke—the second that wire shifts even a tiny bit, the whole laptop just dies instantly. What should my next move be if I don't want to go broke fixing this? To be clear, the cord from the wall outlet to the adapter itself is perfectly fine; it’s just the part connecting the adapter to the machine that's shot. My laptop is a Dell Latitude. I wanted to check here first because I know these cables aren't one-size-fits-all. Every port seems to have its own specific shape and size, and since I'm definitely not an IT pro, I really don't want to guess and end up buying something useless.
