Home › IT › Hardware › Desktops › Need help: Fastest and quietest build for under $450?
Started by wearytinker8 · · 👁 10 views · 6 replies
Participants wearytinker8Robert Rodriguez2crimsonstag84swiftfalcon89
wearytinker8 wearytinker8 Active MemberOP
57 messages
Hey everyone!
I’m pretty much clueless when it comes to PC hardware, so I’m hoping someone can point me in the right direction for picking out parts for a new build.
It’s mostly just going to be for basic stuff—browsing the web, watching movies, listening to music... what I really care about is keeping it quiet and snappy. Ideally, I want a 240 GB SSD and a 500 GB HDD, all while trying to stay under $1000.
One SanDisk Z400s 256GB SSD, 2.5”, 7mm, SATA 6 Gbit/s—pulling 60mj.
One Seagate BarraCuda 500GB, 64MB, 7200rpm, High-Performance.
High-Performance 2 x Corsair Vengeance 4GB DDR3 1866MHz
One black MS KNIGHT case, no power supply included.
Just one AMD A8 x4 7600 Corsair DDR3 HyperX.
MSI A88XM-E (SFM2+, DDR3, USB 3.0, SATA III, mATX) with DVI/VGA/HDMI.
Standard 4-pin CPU cooler, works with both Intel and AMD.
Total: $918
You forgot the power supply 😛
Just trying to get things a bit more compatible for the USA and downtown...
EDIT:
AMD A8 x4 7600 Corsair DDR3 HyperX Fury processor
Kingston DDR3 HyperX Fury, 1866MHz, 8GB Black HX318C10FB/8
EVGA 400W power supply, 80+, active, 12 cm
SanDisk X300 256GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 520 MB/s / 470 MB/s, Samsung 850 EVO
Zalman mini tower case black, ZAL-A1
Seagate DT01ACA050 500GB 3.5''
LC Power CPU Cooler LC-CC-95 - 90mm
ASUS Main board desktop AMD A68 (A68HM-DS2)
Total: $979 Downtown
crimsonstag84 said:You forgot the power supply. 😛
If only things worked better between the USA and downtown.
EDIT:
The AMD A8 x4 7600 Corsair DDR3 HyperX Fury.
EVGA 400W. 80 Plus, active cooling, 12cm fan.
Samsung 850 EVO 256GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 520 MB/s / 470 MB/s, Samsung 850 EVO
Zalman mini tower case, black, ZAL-A1.
The LC Power LC-CC-95 90mm cooler is just another basic heatsink. It does the job if you're building a budget rig, but don't expect miracles.
All in all: $979 Downtown.
Unbelievable. What a joke. 😁 Happens to the best of us. Building a PC after a long night of drinking is always a disaster. 🤣
57 messages
Thanks, guys!
Got another question for you...
When I'm installing Windows on either of these two setups, do I actually need to worry about whether they're 32-bit or 64-bit?
swiftfalcon89 swiftfalcon89 Active Member
85 messages
joined Aug 2013
wearytinker8 said:Thanks, everyone!
One more thing...
When I'm installing Windows on either of these two setups, do I need to worry about whether I should go with a 32-bit or 64-bit version?
You definitely want a 64-bit OS. If you go with 32-bit, you won't be able to use more than 3.5GB of RAM.
57 messages
swiftfalcon89 said:You're going to need a 64-bit OS... because 32-bit just can't handle more than 3.5GB of RAM.
