Home › IT › Hardware › Desktops › Need help with BIOS and graphics card settings
Started by darkbadger12 · · 👁 5 views · 5 replies
Participants darkbadger12Benjamin King2Sandra Cook60fadedorca66
darkbadger12 darkbadger12 NewcomerOP
Hey there—I’ve been hitting a bit of a wall here. I just can't seem to track down the BIOS for my GeForce GT Series graphics card (the one with the 1GB GDDR5 memory)! If anyone happens to know where I can dig this up, I would truly appreciate the help. Thanks so much!
Have you actually tried asking on their official support forums yet? And honestly—why on earth would you even need a BIOS update for this?
So, here’s the situation—I picked up this specific card for my brother, but it turned out to be a complete dud right out of the box. I figured I might be able to flash it back to life, but since I couldn't track down the original BIOS, I tried flashing one from a GeForce GTX Series instead. That immediately killed my video output entirely, leaving me with zero signal to even save the current BIOS! I tried a different version, but that didn't really solve anything either. Now, the card will only output via HDMI, and even then, the screen is just a mess of lines and artifacts. It’s driving me a bit crazy. I’ve been troubleshooting this as best I can, and my gut feeling is that it isn't a memory issue—if the memory were shot, I'd expect those artifacts to show up on all three outputs, not just the HDMI port. I’ve been scouring Google for hours, but I’m hitting dead ends and I'm honestly not sure which BIOS might actually work. I usually love tinkering with this kind of hardware—it's a fun hobby for me—but I'm stuck. If anyone happens to have this exact card or knows where I can find the correct BIOS dump, could you please share it? I'm trying to figure out if this thing is salvageable or if I should just cut my losses and buy a replacement. Between work and everything else, I don't have nearly enough time to spend chasing ghosts.
Sandra Cook60 Sandra Cook60 Active Member
I couldn't find anything for the GeForce GT Series either, but if I were you, I'd look into the GeForce GTX Series.
http://www.techpowerup.com/vgabios/6...24-091002.html
http://www.techpowerup.com/vgabios/i...GDDR5&memSize=
I was actually planning on posting my specs too, but I can't seem to get them to stay put—the page just clears out entirely! It’s a bit frustrating, honestly. Anyway, I wanted to show what I'm working with, especially since this GeForce GTX Series is definitely a step up from the GeForce GT Series I used to have.> NVIDIA GeForce Graphics Card
GPU Clock 700 MHz
Memory 1GB GDDR-5
Memory Type DDR-5
Memory data rate 4.6Gbps
Memory data width 128 bit
CPU Bus PCI Express x16 Rev 2.0
Memory Clock 1.15GHz
HDMI Support Yes
HDCP Support Yes
Shader Processors 720
Texture Units 36
TDP Power Consumption
The thing is, the 5770 version pushes an 850 MHz GPU clock and has a much faster memory clock...
Eh, I don't know, maybe try one of these:
http://www.techpowerup.com/vgabios/i...=&memSize=1024
