Home › IT › IT Support › Need help with installation
Started by Samuel Sanders6 · · 👁 5 views · 3 replies
Participants Samuel Sanders6ironcyclist58
Samuel Sanders6 Samuel Sanders6 MemberOP
joined Jan 2015
Hey everyone,
I'm running into a bit of a headache while trying to install some software.
The installation folder contains three virtual discs.
It’s basically cd1, CD2, and cd3 all bundled within an ISO file.
Once I finished installing WinZip, I opened up cd1, located the setup.exe, and kicked off the process. Everything seems to be cruising along smoothly until it hits the 20% mark, at which point it starts demanding CD2.
I try to follow the exact same steps I used for cd1, but the installer just throws an error at me, claiming I haven't "ejected" cd1 yet.
Does anyone have any idea how to bypass this loop?
Thanks in advance,
863 messages
Don't bother trying to open that with WinZip. You're better off using a virtual drive tool, like Daemon Tools or something similar.
joined Jan 2015
I gave that a shot too, but I’m hitting the exact same wall.
I mean, I can't be 100% certain I followed their setup guide to the letter—they throw a whole mountain of extra software at you during the process—but I grabbed the free version straight from their website.
863 messages
Did you actually run an "unmount," "eject," or whatever that command is to kick the disc out before you tried opening the next one?
