I am currently using a Corsair RM450 power supply, and earlier today, I detected a faint, rather concerning scent of something burning emanating from the unit. Upon opening it up to investigate, I discovered that the internal fan simply refuses to spin; I even attempted to nudge it manually with a small stick just to see if it had perhaps seized up, but while it moves slightly, it seems quite sluggish. When I tried restarting the system, I noticed once again that the fan remains completely stationary—though, I must ask myself, is it actually designed to remain idle until certain thermal thresholds are met? I am somewhat unfamiliar with how these smart fan controllers function. Beneath this specific power supply, I have an additional fan installed at the rear of the case that is functioning perfectly, and my Scythe Katana CPU cooler is also spinning without issue. Does this particular model feature a temperature-dependent fan curve that might explain the inactivity, or should I be more worried? Is it possible the fan motor has finally given out, or could the presence of those two other fans providing airflow somehow prevent it from engaging? Furthermore, is there any specialized software or diagnostic tool available that would allow me to stress-test the component to see if it is truly failing?
The system specifications are as follows: an Intel Core i5 running at 2.67 GHz, an AMD Radeon HD 6800 graphics card, and 8GB of RAM.
I would truly appreciate some assistance. 🙂
