Home › IT › IT Support › There was a problem starting...
Started by Larry Ortiz5 · · 👁 4 views · 3 replies
Participants Larry Ortiz5rustywalker1coppersailor28
Larry Ortiz5 Larry Ortiz5 RegularOP
It looks like you're missing a DLL file—honestly, I can't say for certain which one it is right now. You don't really have anything to lose by just downloading and installing the trial version to see if that clears things up.
http://www.dll-files.com/fixer/
rustywalker1 rustywalker1 Active Member
89 messages
joined Jun 2011
So I installed this and ran it. Now what? How am I supposed to know what’s missing? If I had known, I wouldn't have bothered downloading 😁
Yesterday, I switched from Avast to AVG. Maybe the installation didn't fully complete, who knows? I'll give this a shot and see where we stand.
rustywalker1 said:So I installed this and ran it? What now? How am I supposed to know what's missing? If I knew, I wouldn't have downloaded this 😁
try with "Autoruns" (it's portable; 550 KB zip)
Since you don't actually know which specific program is triggering that error (you usually don't see the notification until you attempt to launch something), it’s likely an issue with an autorun file.
Open "Autorun" and once the scan finishes, look for the highlighted entries... the yellow ones, for instance...
(click on a tab like "Everything," then check the "image Path" column for any "File not found: ..." entries) ... then just uncheck the box next to it, or resolve the issue properly.
Yesterday I swapped out Avast for a new antivirus (AVG). Maybe the installation didn't fully complete. I'll try this and see.
That's a possibility. The old AV might not have been uninstalled correctly (for example, a leftover autorun file is still trying to "call" a file that no longer exists on your system).
89 messages
joined Jun 2011
I just cleared out all those yellow flags, so let's see how things play out.
