Home › Lifestyle › Health › URGENT: Need help with CT scan results!!!
Started by crimsonmason8 · · 👁 4 views · 9 replies
Participants crimsonmason8fadedmarlin402fadedheron892Alex Patel96placidjackal36
crimsonmason8 crimsonmason8 MemberOP
joined Nov 2009
Hey, if there’s a doctor lurking online, can you just walk me through something? I need to know if they absolutely have to use contrast dye when doing an orbital CT—which, from what I gather, is basically just a head CT... Is that stuff actually dangerous?
Also, is it true that the radiation from a CT scan is like, a hundred times stronger than a standard X-ray?😲
Thanks...
fadedmarlin402 fadedmarlin402 Active Member
154 messages
joined Apr 2010
The contrast agent is injected based on the specific clinical scenario, and honestly, there’s no real danger involved—aside from the occasional rare allergy to certain agents, which isn't much of an issue in my experience. At its core, a CT scan is just a rotating X-ray machine. Naturally, the longer the duration of the scan, the higher the radiation exposure. That said, the risk from radiation is negligible, especially if you aren't getting these scans done constantly.
fadedheron892 fadedheron892 Active Member
57 messages
joined Nov 2009
So some physiatrist just told me a CT scan hits you with about 45 rads of radiation.
57 messages
joined Nov 2009
If you're young, stick to MRIs since they don't hit you with radiation, whereas CT scans are pretty much a last resort
154 messages
joined Apr 2010
fadedheron892 said:For younger patients, an MRI is usually the way to go since there's no radiation involved, whereas CT scans are pretty rare for them.
Look, we can't just swap out a CT for an MRI every single time. It's simply not possible.
I’ll say it again: the actual absorbed dose depends on a massive range of variables. If you aren't getting CT scans constantly, the risk is practically nonexistent. As a general rule, you shouldn't even be undergoing a CT scan more than once a year...
joined Nov 2009
fadedmarlin402 said:The contrast dye just depends on what they're looking for, and honestly, there’s zero real danger involved—unless you happen to have some super rare allergy, but even then, it's usually fine. A CT scan is basically just a rotating X-ray machine. The longer you're in there, the more radiation you soak up, but the risk is pretty much negligible, especially if you aren't getting scanned every other week.
I am actually terrified of that contrast dye 😲, I seriously hate the idea of someone sticking a needle in my vein, brrrr, it scares me so much I almost want to just bail on the whole thing...
Plus, I was doing a little digging online and apparently for some CT scans you have to be completely naked... they didn't even mention that to me, which is just such a crappy way to handle things...
Alex Patel96 Alex Patel96 Active Member
139 messages
joined Apr 2009
I don't get it. I had a brain CT scan recently. There was zero contrast used, and the whole thing was wrapped up in maybe three minutes tops.🤷
I honestly don't see how an orbital scan would be any different.😕
joined Nov 2009
Alex Patel96 said:I don't get it. I had a brain CT scan done, there wasn't even any contrast used, and the whole thing was wrapped up in maybe three minutes tops...🤷
I honestly don't see how things would be any different when they're looking at the orbits.😕
Thanks for that... guess I can stop freaking out then. Now I might actually get some sleep...🙂
placidjackal36 placidjackal36 Active Member
183 messages
joined Jan 2008
crimsonmason8 said:Honestly, the whole contrast dye thing totally creeps me out 😲. I can't stand the thought of anything being injected straight into my veins—it’s enough to make me want to just walk away from the whole appointment.
Plus, I was doing some digging online, and apparently, you have to be fasting for certain CT scans. No one bothered to mention that to me, which is just great...
I don't get why you're so worked up. You won't even feel it, and it isn't like it's harmful. Think of it as just a slightly more intensive version of a standard X-ray, but that's life. Nothing is going to happen to you, just like it doesn't happen to the thousands of people getting these done every single year.
139 messages
joined Apr 2009
placidjackal36 said:I don't get why you're so worked up about this. You won't even feel a thing, and honestly, it isn't harmful. It’s just diagnostic imaging—a bit more invasive than a standard X-ray, sure, but that's all it is. Nothing's going to happen to you, just like it doesn't happen to the thousands of people who get this done every single year.
Have you ever actually had an orbital CT scan? Let's clear up exactly what they're doing during the procedure.🤣 Is there damn contrast involved or not?!
