Home › Miscellaneous › Forum Help! › Help! What's going on with Reddit?
Started by nimblecanyon · · 👁 21 views · 69 replies
Participants nimblecanyonboldstag45Sophia Scott5Nathan Fox94rustywalker1Kevin ScottAndrew Booth29Jacob Foster11Angela Cox4mellowfox6Arthur Thompson11cosmicrider5granitebadger7Susan Parker2jadetrucker43cosmicskipper39rustywalker17Richard Kelly7Kevin Garcia70Robert Evansmellowskipper91Gregory Doyle3driftingcobra58swiftridge29 …
Scott Stewart6 Scott Stewart6 Newcomer
Quick tip for Chrome users stuck in redirect loops
Since Google Chrome will cache Your 301 redirects, you'll probably find yourself stuck. If you want to keep your current tabs alive without losing everything, just clear out the cache.
Wrench > Options > Privacy > Click Clear browsing data...
Check whatever boxes you need, but just make sure "Empty the cache" is selected.
Hit "Clear browsing data" and you should be good to test it again.
Honestly, nothing else really matters—just focus on that bolded part.
Who on earth was messing around with the forum settings?
Why does mine look like this? 😕
jadetrucker43 jadetrucker43 Active Member
168 messages
joined Dec 2018
So, what's the ideal setup supposed to look like then? What exactly is broken about this?
jadetrucker43 said:So what’s it supposed to look like then? What’s the big problem here?
Well, how about something like this:
it's just that those sports PDFs always end up looking like this
rustywalker1 rustywalker1 Active Member
89 messages
joined Jun 2011
I'm not sure. Is it just width or something else?
168 messages
joined Dec 2018
The sports subforums are running some Gillette ads on the sidebar right now, though you probably have them blocked out anyway. Just deal with it—usually, these ad spots are bought for specific time slots.
analogstag29 analogstag29 Member
joined Mar 2011
It doesn't matter what I try to click on or which link I attempt to open, I just sit here waiting and waiting, and honestly, it feels like my old dial-up connection from ten years ago was actually faster than this. Everything else on the web loads perfectly fine for me—I can jump into any other site and get an instant response—but "Reddit," specifically this forum, is just sluggish and incredibly slow. No matter where I click, I’m stuck staring at a loading screen for 15 or even 20 seconds before anything happens.
Alex Walker8 Alex Walker8 Member
joined Mar 2011
analogstag29 said:No matter what I click or try to open, I'm just sitting there waiting. Honestly, my old dial-up connection from ten years ago felt faster than this. Everything else loads instantly—any other site works fine—but this American forum is incredibly sluggish. I'm stuck waiting 15 to 20 seconds for every single action, regardless of what I click.
Wow, only 15-20 seconds? That doesn't sound too bad to me.
By the time I click a link and whip up half a lunch, the page finally opens. Click, eat, finished.
That’s been my routine for three days now.☕
rapidcanyon5 rapidcanyon5 Newcomer
joined Jan 2015
I'm having some trouble getting this forum to load while I'm here in Indonesia. Every other site I visit seems to work perfectly fine.
I've already tried using Chrome, Mozilla, and even IE.
It’s always the same result.
The page takes forever to load, and when it finally does, it usually just shows this in the browser bar:
, but nothing actually appears—it's just a blank white screen.
Or, if I actually manage to get a post written, it eventually throws a 408 Request Time-out error at me.
Any ideas?
Thanks in advance.
Kevin Garcia70 Kevin Garcia70 Member
43 messages
joined Feb 2010
Robert Evans, I click through, head over to the store, then come right back, and the forum still hasn't loaded. This isn't normal behavior. Get this fixed once and for all. Also, your servers have been acting completely haywire today—I'm constantly hitting 503 and 504 errors.
joined Jan 2015
Does anyone from the admin team ever actually show up around here?
William Reyes12 William Reyes12 Newcomer
What's their deal with that?☕
slyviper6 slyviper6 Member
As of this evening, the forum speed has finally returned to normal for me.👍
89 messages
joined Jun 2011
It’s been running fine for me for quite a while now. It was just as slow before. I’d suggest installing an adblocker; things started behaving once I did. Is that really all it took, or am I missing something else? Who knows.
89 messages
joined Jun 2011
The forum is acting up again. Sometimes it opens a thread without loading all the posts, and then when I try to refresh, it takes forever to actually load 🙂
Drew Scott67 Drew Scott67 Newcomer
Hey, can someone tell me why my post count is stuck at zero? It’s just sitting there showing 0... ??
EDIT - Okay, looks like it finally kicked in. 🙂
89 messages
joined Jun 2011
Wait, why is everything suddenly in English? 😕
melloworca6 melloworca6 Regular
551 messages
joined May 2010
rustywalker1 said:Why is everything suddenly in English? 😕
Just go to opcija - ured opcija - forum Language (all the way at the bottom of the page) and select English. 🙂
89 messages
joined Jun 2011
melloworca6 said:Go to Options - Edit Options - forum Language (all the way at the bottom of the page) and select English. 🙂
Thanks. I have no clue why everything shifted. I didn't touch any settings. One minute it's in English when I log in, the next I check my options and it claims it's already set to English. 🤷
551 messages
joined May 2010
The same thing happened to me a couple of times. I didn't touch a single thing. 🤷
