Home › IT › IT Support › Audio and headphone issues
Started by Sandra Castillo55 · · 👁 3 views · 13 replies
Participants Sandra Castillo55Sam Rodriguez51Larry Ortiz5
Sandra Castillo55 Sandra Castillo55 NewcomerOP
My laptop speakers have been broken for quite some time now... so I have always just relied on headphones. My headphones recently gave out, leaving me without any audio for about two weeks. During that time, I did a bit of digging into the speaker settings and spent some time tinkering around in the Control Panel... Now that I finally have a new pair of headphones, I've realized that nothing works on my laptop at all, even though they work perfectly fine on my phone. Could anyone please help me? I am worried I might have accidentally changed a setting or deleted something important...
And now I'm being told I need to reinstall Realtek... how on earth did that happen?
Sam Rodriguez51 Sam Rodriguez51 Member
First off, tell me which laptop you're rocking and what OS you're running. Is it 32 or 64-bit? Once I know that, we can actually get moving.
It’s 64-bit... and I managed to figure out which motherboard I'm running by using CPU-Z. It says Motherboard Dell Inspiron... though I am unsure if I need to look into the chipset details as well. Also, I just checked the Control Panel and Device Manager, and there is a yellow warning triangle right next to the Realtek integrated audio...
Which version of Windows are we talking about? 7, 8, or XP?
EDIT: And which specific HP model is that exactly?
Windows 7
HP 550
And just give me the exact laptop model number too.
I updated the details in the edit section for the HP 550 🙂 ..unless there is something else I should include, because that is everything I can recall 😁 :O
I also checked the properties for the Realtek driver, and I'm getting this message: "Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)." I honestly have no idea what I did to cause this...
Just head over to Google, search for your specific laptop model and manufacturer, then grab the audio driver from there and get it installed.
I restarted my computer, and now the system claims everything is functioning correctly. Yet, there is still no sound. It’s quite baffling... I wonder if uninstalling the current driver will resolve this? And should I make sure to remove the existing Realtek driver first?
Yeah, go ahead and uninstall that Realtek audio driver through the Control Panel first—then just give the system a quick restart. Once you're back up and running, you can try installing the specific driver you downloaded from the laptop manufacturer's site 🙂
Thank you very much. However, it seems to have started working on its own... even that error with the exclamation point in the triangle disappeared... 😁 haha, though I recently dealt with a black screen issue and that also resolved itself without any intervention :/
It happened again... I encountered the exact same error, even though I haven't changed a single thing this time...
