Home › IT › Hardware › Desktops › Audio issues / No sound
Started by slypuma4 · · πŸ‘ 5 views · 4 replies
Participants slypuma4Adam Moore3
slypuma4 slypuma4 NewcomerOP
joined Jan 2015
Hi there 😁
I am having some trouble with my audio setup, to put it briefly 😁
My PC has an integrated sound card as well as a dedicated sound card I added separately...
When I install Windows XP, the audio only works through the integrated card, while the dedicated one remains silent (even though I installed the driver using DriverPack Solution 2014)
However, when I install Windows 7, the audio works perfectly fine through the dedicated sound card...
Where is the issue?
So okay, are you actually planning on using XP anyway? You mentioned everything works fine on Windows 7, so I assume that's what you're running. And seriously, stay away from DriverPack Solution and all that other junk for downloading drivers. Find them manually; those programs are garbage, every single one of them, at least based on my experience. Just check your sound card model, head over to the manufacturer's website, and download the driver directlyβ€”you can't really mess that up. Those automated tools often end up installing completely wrong or outdated drivers.
joined Jan 2015
Adam Moore3 said:Fair enough, but are you actually planning on using XP? You mentioned everything runs fine on Windows 7, so I assume that's your main OS. Also, stay far away from DriverPack Solution and those other driver update tools. Find them manually; those programs are garbage, at least in my experience. Just identify your sound card model, go straight to the manufacturer's website, and download the driver from there. It’s foolproof. Those automated tools often install outdated or completely incorrect drivers.
Honestly, this machine is basically a paperweight :3. My actual PC for heavy liftingβ€”like gamingβ€”is currently broken, so I won't have access to it for a while... what a pain...
By the way, when I listen to music, I crank the volume all the way up. The quality from the integrated audio is pretty weak compared to this dedicated card I just installed. That's really the only reason I'd even bother with XP, since it isn't demanding. This is just meant to be a backup computer.😁
slypuma4 said:honestly this thing isn't even a computer, it's just a glorified trash can :3 since my actual rig for heavy lifting and gaming is totally busted right now, so I won't be getting it back for a while... total crap...
anyway, when I listen to music, I crank it up to the max, and the sound quality on integrated audio is way worse than what I get from this dedicated card I threw in... that's basically why I'm using Windows XP, since it doesn't need much power... still, this machine is just a backup😁
Gotcha, alright then. What specific card did you plug in there? I'll send you the links for the drivers so you can just grab them and install them manually on Windows XP.
joined Jan 2015
It just shows ES1938-4CH on my sound card
