Home › IT › IT Support › Battery issues?
Battery issues?
Started by Arthur Thomas13 · · 👁 5 views · 10 replies
Participants Arthur Thomas13ironcyclist58Larry Ortiz5Michael Jackson10Bryan Palmer9swiftowl7
Arthur Thomas13 Arthur Thomas13 NewcomerOP
joined Mar 2015
Hello,
I recently picked up a replacement battery (Green Cell) on eBay for my six-year-old laptop. I’ve mostly used the machine for light web browsing and some basic office work. For the last two years, I haven't been using a battery at all—it has just been running directly off the power adapter. However, after I installed this new, fully charged battery, the laptop started shutting down unexpectedly every 15 to 30 minutes or so. I guess I am wondering what the issue might be... do you think the problem lies within the laptop itself, or could it be the battery?
Thanks, lp
863 messages
If it was manufactured in China, you can bet the battery is absolute garbage. Seriously, stay far away from flash memory and batteries coming out of China...
joined Mar 2015
The seller is based in the United Kingdom, though I recall seeing similar shops back in the day here in the States. The price was $100, and my whole intention was to avoid buying any cheap Chinese junk... Should I just ship it back, or should I be pushing for a full refund if there's actually an issue with the laptop?
Maybe try testing the laptop without the battery plugged in... if it stays running fine without it, but shuts down whenever the battery is connected, then you've pretty much found your culprit right there.
joined Mar 2015
Larry Ortiz5 said:Maybe try testing the laptop without the battery... if it stays on without it, but shuts down when the battery is plugged in, then I guess you'll know exactly what the issue is.
Thanks, I think I understand that part, but I suppose I was wondering if it's possible that some internal circuitry near the battery port got damaged from being left plugged in for so long? (The old, broken battery was sitting in there the whole time).
Arthur Thomas13 said:The seller is based in the United Kingdom, but I remember seeing stuff like this in local US shops back in the day. It cost $100, and my whole plan was to steer clear of Chinese junk... Should I just ship it back or fight for a refund if the laptop itself is actually busted???
So the seller is out of the United Kingdom, and we're supposed to believe a Chinese battery suddenly gains some "British quality" magic touch just because of that?
Look, your battery is Chinese and it's garbage. Think about it: someone manufactured it, shipped a massive container full of them over to America to turn a profit, and that's that.
Some guy acting like a total Del Boy out in a suburb near Packham grabbed them and decided to flip them for a quick buck.
Here's the kicker: What do you think the actual production cost of that battery is?
I'm not saying "official" batteries cost a fortune, but they go through quality control checks to protect the brand's reputation, which naturally drives the price up. How much? Just enough to cover the cost of an actual genuine part...
Arthur Thomas13 said:Thanks, I get that. But I meant to ask—is it possible that some internal electronics went haywire because the old, dead battery sat in there for ages while plugged in?
From what I know about how laptops are built, there isn't really any specific "side" electronics dedicated solely to a battery that stays plugged in all the time, if that's what you're wondering...
Your "charger" is basically just a power adapter hitting a specific voltage, and the battery is just a bunch of cells wired together. There might be tiny bits of circuitry inside the battery to balance the charge between cells (since they're never perfectly identical) and to tell the charger how full it is.
Inside the laptop, you've just got voltage regulators to handle different power needs, and probably just a direct path to the battery... Once you switch over to battery power, it’s almost certain the laptop uses those same components to run. Honestly, who would bother building separate parallel circuits for that nowadays when everyone is trying to cut costs?
joined Mar 2015
Thanks for providing that second part regarding the electronics, as my understanding of the subject matter is quite limited. From what I can gather, the issue lies within the battery, so I think I will attempt to send it back to the vendor and request a full refund. That was essentially the answer I was looking for when I decided to start this thread. My main question now is, which battery should I purchase if that cheap junk from China isn't any good? Let’s be realistic—almost everything is manufactured in China nowadays, and a brand name is usually the only guarantee of quality. Based on my research, the specific brand mentioned seems to be the only one available for this older laptop model, especially through major US online retailers... I suppose you could find even cheaper, likely lower-quality batteries on eBay, but I'm hesitant.
Bryan Palmer9 Bryan Palmer9 Member
ironcyclist58 said:If it was manufactured in China, there's a huge chance the battery is total garbage. You should seriously never buy flash memory or batteries from China.
Honestly, I've ordered memory sticks from China more times than I can count and I haven't run into a single issue, mostly because I just grab everything through sites like Gearbest where it's way cheaper, and honestly, I've actually ended up with really solid products that work perfectly fine.
I’d even go as far as saying some of them feel better built than those big-name brands, since they actually give you decent metal casings while the famous companies usually just charge you a massive premium for cheap plastic junk.
Back in May of last year, I picked up a bunch of 32GB metal drives for like four bucks each, and man, I have zero complaints because everything fits perfectly, and I even loaded them up with all the photos and videos from my kid's baptism to share with my buddies without any hiccups at all.
863 messages
Honestly, about 99% of those flash drives you pick up on eBay—not from any actual reputable retailers—are just total scams with fake capacity.
+1 I still remember when I picked one up for about $33 a few years back at a local Best Buy—I think it was either a 64GB or a 128GB memory card... I actually remember thinking to myself, "Man, this guy is selling this way too cheap." Of course, that was my first hint. It ended up being one of those situations where every single bit of data I owned just vanished—gone forever. Now, whenever I walk into a store, I just stare at the shelves and think about it.
swiftowl7 swiftowl7 Member
46 messages
joined Dec 2017
Arthur Thomas13 said:Thanks, I get that, but I was actually wondering if it’s possible for some internal electronics to fry right where the battery connects, just from leaving an old, dead battery sitting in there on the charger for too long?
It's definitely possible that the power switch (the crystal oscillator) on the motherboard has given out. It happens quite often, especially when you're running a laptop without a battery installed. I've actually seen that exact kind of failure happen firsthand while working on a machine once. You see similar weird glitches with those tiny micro-switches in tablets all the time, too.
When that specific switch—or maybe even a chip—starts acting up, you get these annoying issues where certain laptops, like an HP for example, will go into sleep mode and then just refuse to wake up unless you physically pull the battery out, along with all sorts of other nonsense.
Now, whether that switch fails because of some faulty circuitry inside an aging battery, a sudden surge through the switch itself, or just plain old wear and tear over time... honestly, I don't think anyone truly knows for sure.
In my experience, you really ought to swap out laptop batteries as soon as you notice a significant drop in capacity, rather than waiting until they completely die on you.
PS: The battery might actually be fine, but if I were you, I'd just run the laptop strictly off the AC adapter for the rest of its life and stop messing around with putting any more batteries in it.
