Hey,
So, I ran into a massive headache with my PC a couple of days ago. I was right in the middle of playing Baldur's Gate when the screen just went totally white out of nowhere. Everything froze up, so I had to do a hard reset on the rig. Now, after it clears the initial BIOS stuff and tries to boot into Windows (I upgraded from Windows 8.1 to Windows 10), the screen just stays pitch black. Nothing happens. I try another hard restart and... yeah, same thing. Total brick.
I’m sitting here thinking maybe the GPU finally kicked the bucket, or maybe the PCIe slot on the motherboard is just shot.
Honestly? I’m leaning more towards the motherboard being the culprit. I’ve been having weird issues with the USB ports lately—they lose connection constantly, and one of them isn't even working at all now. Even the audio jack has been acting flaky. So, yeah, the board is looking pretty suspicious.
Here’s what I’m running (this build is from back in 2013, so it's ancient):
Mobo: MSI B75MA-E31 s1155
CPU: Intel i5-3350P 3.1 GHz/1155 Ivy
HDD: Apple 500 GB SATA2 16 MB F3
GPU: MSI R9 270 2 GB GAMING
RAM: DDR3 8 GB (1x8) Kingston 1600 HX
PSU: XFX 450W
Case: Zalman Z3 Plus mid tower case
Optical: DVDRW Apple Starlink SATA
If it turns out the motherboard is definitely dead, I'm torn. Should I just hunt down a new board with the same old socket and keep everything else as is? Or should I actually step things up a bit? Like, maybe grab a newer motherboard with a modern socket, which would mean swapping the CPU too, and then eventually adding another 8 GB of RAM and an SSD.
Either way, I desperately need some solid recommendations on what to buy.
I've been browsing the sites for Accenture, IBM, and Hard Rock Cafe, but it looks like nobody carries motherboards with the s1155 socket anymore. It feels like I might have to start digging through used markets or something.
Mainly, I use this machine for movies, gaming (nothing crazy on ultra settings), work, and just general daily stuff. Can you guys take a look at my current specs and tell me what kind of components I’d need for an upgrade? I want to make sure I get a higher quality motherboard than the cheap one I have now.
I’m hoping to reuse my existing RAM, power supply, case, graphics card, and the DVD drive if possible.
PSU: XFX 450W
