Home › IT › Hardware › Desktops › Help building an Electronic Arts build!
Started by Samuel Moore70 · · 👁 4 views · 4 replies
Participants Samuel Moore70Amy Vaughn12Kimberly Gomez34Adam Moore3
Samuel Moore70 Samuel Moore70 MemberOP
joined Apr 2015
Look,
I know you guys probably want to throw your keyboards at me because this topic comes up every five minutes, but honestly, that’s what these forums are for—to ask questions and actually get some answers.
I’ve got exactly $1,000 sitting in my PayPal account, and I’m looking to turn that into a brand-new rig.
The whole point of this machine is heavy-duty gaming, specifically titles like GTA V or Fallout 4, where I can crank everything up to high settings without the system choking.
I was hoping you could put together an AMD-based build for me over at Micro Center.
I don't have any specific component preferences, other than the fact that I want an AMD setup. Just work your magic within that $1,000 budget ($2500) to build the tower itself—don't worry about the monitor or peripherals for now.
The second thing on my mind is finding a decent monitor to pair with this beast. I’m pretty clueless when it comes to displays, so I’d just want something Full HD that isn't massive or tiny, maybe something in the $150 to $200 range. And just to be clear, when I mentioned that price range earlier, I wasn't talking about a MacBook Pro; I meant a standard monitor. It doesn't even have to be expensive—if there's a solid one for like $80, I'm all ears!
!!!!To reiterate: the monitor money is separate from the main budget!!!!
Thanks for taking the time!
Amy Vaughn12 Amy Vaughn12 Active Member
121 messages
joined Mar 2009
1 x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box
1 x Gigabyte GA-990XA-UD3, AM3+, 125W CPU
1 x VGA Sapphire NITRO R9 390 8G GDDR5 PCI-E DVI-D / HDMI / TRIPLE DP TRI-X OC VERSION (UEFI)
1 x Kingston HyperX Fury Black 8GB 1866MHz DDR3 CL10
1 x Toshiba HDD 1TB,7200rpm, 32MB
1 x Crucial BX100 250GB SSD, SATA 2.5” 7mm
1 x Super Flower Golden Green 550W, 80+ Gold
1 x Zalman Z3+, USB3.0 black
1 x CPU Hladnjak Raijintek Themis Black, 120mm, PWM
$2502
monitor
http://www.amazon.com/Samsung-Monitor-LED-Display-FreeSync/dp/B07C2R4S5V
joined Apr 2015
Thanks a ton, but if you could throw in an optical drive too, that would be life-changing since I’m still clinging to my old CDs like they're gold...xD 😁
Intel build option:
1 x ASUS B85M Pro3, LGA 1150, supports 4th Gen Intel Core i7 / i5
1 x Intel Core i5-4460 Processor (3.20GHz, 1MB, 6MB, 84 W, 1150) Box
1 x 8GB DDR3 (1x8GB) Kingston Fury, 1866MHz, CL10
1 x Gigabyte GF GTX970 G1 GAMING, 4GB GDDR5, DVI, DP, GVN970G14GD-00
1 x Seagate 1TB HDD, SATA III, 7200 rpm, ST1000DM003
1 x FORTRON 550W Raider PSU, RA550, 12cm fan
1 x Zalman R1 mid tower case. 192(W) x 465(H) x 450(D)mm.
1 x OCZ ARC 100 240GB SSD, featuring the OCZ Barefoot 3 M10 controller
$2498admin.com
