Home › IT › Hardware › Desktops › Help with PC build + a few questions
Started by Jonathan Moore26 · · 👁 5 views · 1 reply
Participants Jonathan Moore26crimsonstag84
Jonathan Moore26 Jonathan Moore26 NewcomerOP
joined Aug 2017
Hey everyone, I could really use some help here. I'm looking to pick up a new PC and have a few questions
I'm pretty much a total newbie at this, so please go easy on me.
I'm assuming building my own rig from scratch is more cost-effective than just buying a pre-built one, right?
Where would you guys suggest I grab parts—maybe somewhere local in the D.C. area or just stick to a major US online retailer? There are so many options out there and I honestly can't tell if they're all just overpriced junk or if there are actually some solid shops worth using. I've heard about sites like PriceGrabber, but for the sake of convenience, I’d really prefer to get everything from a single vendor.
How much of a headache is it to actually put all the components together into a working machine? In the past, I've only ever swapped out a hard drive, a GPU, and an optical drive on my old setup.
One last thing: can anyone recommend a build for around $3,000$1167? Storage space isn't a huge deal for me; I'd be perfectly fine with just 250 GB. I don't need some flashy, RGB-heavy case either. My main priority is just making sure I can pull a steady 100 FPS in Dota and CS:GO.
Best,
LP Rudolf
EVGA Builder Series CX450, 450 Watt Corsair Power Supply
US version processor Intel Pentium G4560
Seagate BarraCuda 1TB, 64MB, 7200rpm HDWD110UZSVA
2x Crucial DDR4 4GB 2400 MHz P/N: CT4G4DFS824A
ASRock B250M PRO4, s.1151, D4, S3, U3, mATX
GIGABYTE Video Card AMD Radeon RX 560 OC GDDR5 2GB/128bit, 1189MHz/7000MHz, PCI-E 3.0, DP, HDMI, DVI
Zalman Z1 mid tower case black, USB 3.0, without power supply ZAL-ZM-Z1
ZAL-ZM-Z1 total: $1167 - Centro
