Home › IT › Hardware › Desktops › Need help optimizing my build
Started by frozencyclist9 · · πŸ‘ 4 views · 8 replies
Participants frozencyclist9Larry Ortiz5crimsonstag84Adam Moore3Kimberly Gomez34Robert Rodriguez2
frozencyclist9 frozencyclist9 NewcomerOP
joined Feb 2015
I've put together a build, but I have no idea if this thing will actually run. Are there better options in this same price range? Help me out. πŸ™‚
Western Digital 1 TB 5400 rpm 64 mb 3.5" Seagate Barracuda $145
ModeCom Logic B26 computer case, black. $55
Samsung 22x SATA DVD burner (SH-224BB/BEBE) black OEM SuperMulti. $42 iGigabyte PCIe AMD R7 260X 2GB GDDR5 - GV-R726XOC-2GD $349
AMD AM3+ FX-6300 - 3.50GHz $274
Gigabyte sAM3+ GA-970A-DS3P motherboard. $183
DeepCool DN500 V2 80 Plus 500W power supply. $127
Kingston 8GB 1333MHz CL9 DIMM DDR3 HyperX Fury Black Series memory. $199
Total cost: $4. $41
I'm still on the fence about the DDR memory. I really want to keep the total around $4,000.
Oh man, this could be done way betterβ€”just hang tight, guys, and we'll get it sorted out.
I’d say grab some cheaper RAM if you can find it, toss in a WD Blue or a Seagate 7200, and maybe pick up an extra coolerβ€”maybe an NVIDIA Kepler or an LC-CC-95.
If you're building this specifically for gaming, I’d suggest going with 4 GB of RAM for now. That way, you can tuck an AMD Radeon R9 270 into those extra $100 slots later onβ€”it's a much beefier cardβ€”and just upgrade the RAM once you've saved up some more $100. You'll end up with a significantly more powerful gaming rig overall.
joined Feb 2015
Thanks for the suggestions. πŸ™‚ Can anyone tell me if these parts are actually compatible? I'm not sure about the socket types or everything else.
edit:
I mostly use this rig for gaming, specifically CS, but I also handle Photoshop tasks for work quite a bit. So, I need something that can pull its weight on both fronts. πŸ™‚
Of course, we would have told you right away if you had put something in incorrectly. πŸ™‚
joined Feb 2015
Alright, thanks. πŸ™‚
Just grab a decent power supply insteadβ€”look at brands like Seasonic, XFX, or even Fortron Hexa+ or Hyper series.
That DeepCool unit is a total wildcard; it’s likely either bottom-tier junk or just mediocre hardware sold at an inflated price, especially since it carries a fake 80+ certification and hasn't seen a single real review.
Also, think about whether buying from Micro Center is actually your best move, considering they're the only ones stocking that DeepCool stuff.
http://forum.pcekspert.com/showthrea...244023&page=46
Since you're building this rig yourself, you have the freedom to mix and match components from different retailers. For instance, the LC-CC-120 cooler is a total steal right now.
1 x Gigabyte 970A-DS3P, AM3+, AMD 970 SB950, 4x DDR3 2000(O.C.)/1866
1 x AMD FX-Series X6 6300 3.5GHz Processor, 14MB, 95W, AM3+, FD6300WMHK
1 x Kingston DDR3 8GB (1x8GB), HyperX Fury, 1866MHz, CL10
1 x TOSHIBA 1TB, 7200rpm, SATA 6 Gb/s, 32MB, DT01ACA100
1 x FORTRON 400W Power Supply, HEXA Plus 400, 12cm fan
1 x MS PHOENIX Case, Midi tower, MBO: ATX, mATX
1 x LG GH24NS DVD burner, DVDΒ±RW, 24x DVDΒ±R ,8x DL , 40x CD-R
1 x NVIDIA Kepler Rev.2 Cooler, 1156/775/FM1, 96.5Γ—51Γ—125 mm ,92mm
1 x Sapphire R7 260X 1GB GDDR5 OC, 1GB GDDR5 128bit, 28nm
$1366
here's something that might work for you
I'd rather go with a beefier GPU with 4GB of VRAM. You'll run into the need for more RAM way before you actually outgrow the graphics card
