Home › IT › Hardware › Desktops › Need help with my build configuration
Started by Dennis Fisher70 · · 👁 3 views · 5 replies
Participants Dennis Fisher70crimsonstag84Amy Vaughn12Robert Rodriguez2Grace Peterson17Benjamin King2
Dennis Fisher70 Dennis Fisher70 NewcomerOP
joined Jan 2014
Since I'm being forced to pick up a new rig for work, I could use a little help picking out the parts. My requirements are pretty straightforward—web browsing and basic apps that don't demand massive resources—but I need everything to run smoothly across four monitors in extended desktop mode. So, I'm looking at a mid-range processor and a matching motherboard. For RAM, I'm thinking 8GB (though I suspect 4GB might actually cut it, so that's not a dealbreaker). As for the GPU, I assume it needs Eyefinity technology along with DisplayPort, HDMI, and maybe two DVI outputs or a DVI/VGA combo. I already have the monitors since I've been using two HP Thin clients—two of them, with two monitors each—but those clients have finally bit the dust, so I'm moving to a single tower driving all four screens. I'll just grab an SSD for now; from what I've looked into, it seems more sensible since I don't really need bulk storage, and I can always slap an HDD in later if the need arises.
My budget is roughly $3,500 to $4,000, so yeah, I'd appreciate any help or suggestions you guys have.😉
MS PLUTOS case without power supply
XFX Pro Series CoreEdition 80 450W PSU, XFX-P1-450S-X2B9
Samsung DVD±RW 24x black, bulk
XFX HD7850 2GB 975m PciEx, XFX-FX-785A-CDBC
ASRock FM2A88M EXTREME4+ motherboard
AMD Athlon ii x4 740 processor
Kingston 120GB SSD, SSDNow V300 SATA 3 SV300S37A/120G
Adata DDR3 8GB 1600MHz, AD3U1600C2G11-R
Total: $4,078.66+$27 shipping Newegg
The GPU has 2xDP, HDMI, and 2xDVI. If those ports $50 are the issue, then maybe just grab 4GB of RAM.
Amy Vaughn12 Amy Vaughn12 Active Member
121 messages
joined Mar 2009
1 x AMD FX-Series X6 6300 3.5GHz, 14MB, 95W, AM3+, FD6300WMHK
1 x DDR3 4GB (1x4GB) Kingston, 1600MHz, CL9, Hyper X, KHX1600C9D3B1/
1 x CORSAIR 430W CX Series 80+ Bronze, EPS12V v2.3, 80+
1 x Samsung SH-224DB sat Bulk Black, SATA
1 x Kingston 120 GB V300, 2.5" 7mm, SATA 3 6G, 7mm to 9.5mm
1 x Asrock 970 Extreme3 R2.0 - AMD 970, AMD SB950, ATX, Dura Caps
1 x Thermaltake Contac 16, 775, AM2, AM2+, AM3, AM3+, FM1, 1155, 1156
1 x Sapphire R7 260X 2GB GDDR5 OC, 2GB GDDR5 128bit, 28nm
1 x MS LOGIC A30 without power supply, Midi tower, ATX
$1360
Newegg
1 x ASRock FM2A88M EXTREME4, FM2,FM2+, AMD A88X (Bolton-D4), DDR3
1 x AMD Trinity Athlon ii x4 750, 3.40GHz, 4 cores
1 x 8GB DDR3 Kingmax, 1333MHz, non-ECC, CL9.0
1 x Zalman ZM-T4 micro tower case. 189(W) x 427.5(H) x 364(D)mm. MB
1 x ASUS DRW-24F1ST/BLK/B/AS SATA, DVD-R 24x, DVD-RW 6x, DVD+R 24x
1 x Sapphire R7 260X 1GB GDDR5 OC, 1GB GDDR5 128bit, 28nm
$1304
Grace Peterson17 Grace Peterson17 Member
47 messages
joined Dec 2013
AMD FX-6300 box
ASUS M5A78L-M LX3
DDR3 PC1600 4GB CL11 Crucial
Sapphire RADEON R9 270X Dual-X OC with Boost
Toshiba 500GB 3.5" 7.2k SATA III 32MB
XFX PRO550W
LC-Power PRO-923B - Red Captor
4 $20 Newegg
crimsonstag84 said:MS PLUTOS case without power supply
NVIDIA GeForce RTX Series 80 450W PSU, XFX-P1-450S-X2B9
Apple DVD±RW 24x black, bulk
NVIDIA GTX 1050 Ti, XFX-FX-785A-CDBC
ASUS Prime Motherboard
Intel Core i3
SanDisk 120GB, SSDNow V300 SATA 3 SV300S37A/120G
Total: $4,078.66 +$27 shipping Best Buy
The GPU has 2xDP, HDMI, and 2xDVI—so if those ports are the issue, $50 then just grab the 4GB RAM.
If I were him, I'd cut costs on the graphics card rather than the RAM—modern browsers will absolutely devour RAM before you can even blink.
The 260x should be plenty in terms of connectors, plus it’s $67 cheaper.
