Home › IT › Hardware › Desktops › Need help with my build!
Started by cosmicbison20 · · 👁 6 views · 9 replies
Participants cosmicbison20Robert Rodriguez2crimsonstag84Amy Vaughn12Kimberly Gomez34analogtiger19Adam Moore3
cosmicbison20 cosmicbison20 NewcomerOP
Hey everyone.
I'm looking to pick up a new rig, but I'll be honest—I don't know my way around PC components very well. If anyone would be willing to help me put together a build in the $5,000–$5,500 range, I’d really appreciate it. I'm thinking about just heading over to Micro Center or maybe Best Buy so they can assemble it for me right then and there. I definitely need a motherboard with 7.1 surround sound support, and everything else should be geared toward gaming: RAM, processor, graphics card, power supply, a cheap case, and an SSD. Thanks.
ADM setup - click here
Everything seems fine, I just don't get why on earth they'd use a 120GB SSD for $167 😬
Amy Vaughn12 Amy Vaughn12 Active Member
121 messages
joined Mar 2009
The link isn't loading for me, but I suppose if there's something better out there for less money, then fine by me.
1 x Intel Core 3 2200G (3.7GHz,6MB,65W,AM4) box, RX Vega Graphics,
1 x ASUS Prime B350M-A
1 x EVGA GeForce GTX 1060 WF2 OC, 3GB GDDR5
1 x Seagate BarraCuda 1TB, 64MB, 7200rpm
1 x Crucial DRAM 8GB Kit (4GBx2) DDR4 2400 MT/s (PC4-19200) CL17 SR x8
1 x Kingston SSD 120GB A400 NVMe 2.5 SSD (7mm height), , TBW:40TB,
1 x Tron Hexa 85+ 450W, 80+ Bronze, ATX
1 x Zalman Z1, 2x120mm
Total: $1915
Best Buy
This looks a bit better:
ASUS Prime B350M-A Motherboard, AM4 socket, 7B38-004R
Intel Core 3 2200G Processor, 3.50GHz, 4MB Cache, AM4 socket, YD2200C5FBBOX
120GB Western Digital WD Green PC SSD 2.5", WDS120G2G0A
1TB Western Digital Blue High-Performance HDD, 3.5", 7200RPM, 64MB Cache, NVMe, HDWD110UZSVA
Fortron 550W Hexa 85+, ATX 2.4 Power Supply
Zalman Z1 NEO mid tower case
8GB (1x8GB) DDR4 PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16S-8GISB
EVGA GeForce GTX 1060 3GB GDDR5, 192-bit, 1847/8008 MHz
Total: $1.75 - ADM
Thanks so much, guys. I'll take a look at this sometime today.🙂
Sometimes with Imgur, you have to manually strip the "i." out of the URL just to get the image to actually render correctly.
Timothy Kim60 said:Sometimes with Imgur, you have to strip the "i." out of the URL just to get the image to actually show up.
The picture loaded fine for me. I don't know what his problem is.
analogtiger19 analogtiger19 Active Member
134 messages
joined Dec 2016
Timothy Kim60 said:With Imgur, sometimes you have to strip the "i." out of the URL just to get the image to show up.
For me, it’s the opposite—I have to delete the .jpeg or whatever file extension is at the end just to get the link to actually work.
Robert Rodriguez2 said:The image loaded fine for me, I have no idea what the issue is.
I don't get it either. One minute all the links from this American forum go straight to Imgur, and the next, I'm stuck manually editing extensions like I mentioned before...
Timothy Kim60 said:Sometimes with Imgur, you have to manually delete the "i." from the URL just to get the image to actually show up.
For some reason, my browser just opens it in incognito mode automatically, strips the "i" from the URL, and loads everything perfectly fine.🤷
