Home › IT › IT Support › PC keeps shutting down with BSOD: "A problem has occurred and Windows has shut down to prevent damag
Started by ambergull · · 👁 8 views · 9 replies
Participants ambergullgoldenviper13Karen Robinson2electricharbor30
ambergull ambergull MemberOP
Greetings, I find myself facing a bit of a dilemma.
For the past few days, whenever I boot up my PC, I am greeted by a BSOD stating: "A problem has occurred and Windows has shut down to prevent damage."
The error message also indicates whether this is the first time the system has crashed since booting; if it is, I simply restart the machine... At which point, everything seems to function perfectly fine for the remainder of the day until I eventually power it down. Then, come the next morning, the exact same cycle repeats itself.
I am currently running Windows 10 Home. I haven't installed any new software recently, and I have already performed several scans using various antivirus and anti-spyware tools.
Does anyone have any insight into how I might resolve this?
goldenviper13 goldenviper13 Active Member
53 messages
joined Feb 2016
ambergull said:Greetings, I find myself facing a bit of a dilemma.
Grab the little utility BlueScreen View http://www.nirsoft.net/utils/blue_screen_view.html and run a scan with it. That should help you pinpoint exactly what's causing the crash—whether it's a driver, hardware failure, or a software conflict.
Karen Robinson2 Karen Robinson2 Member
joined Sep 2010
Either WhoCrashed
electricharbor30 electricharbor30 Active Member
50 messages
joined Apr 2012
Next time you see that BSOD popping up, maybe grab a pen and jot down that error code at the bottom of the screen—you know, that thing starting with zero x followed by a bunch of numbers... then once the computer is actually working again, just Google that specific code and look through some online forums to see what people are saying about it...
goldenviper13 said:Grab the little utility BlueScreen View http://www.nirsoft.net/utils/blue_screen_view.html and run a scan with it. That should help you pinpoint exactly what's causing the crash—whether it's a driver, hardware failure, or a software conflict.
I have downloaded the software and launched it, yet I find myself staring at a completely blank interface. There isn't a single option for scanning to be found—everything appears entirely empty. Is anyone else experiencing this?
Karen Robinson2 said:Either WhoCrashed
Here are the results:
Is there anything more maddening than staring at a frozen screen, wondering where it all went wrong? I’ve spent far too much time lately diving into crash dump analysis, trying to make sense of the digital wreckage left behind after a system failure. It feels like being a forensic investigator, but instead of a crime scene, you're dealing with lines of hex code and cryptic error messages. When the dreaded BSOD strikes, most people just hit the restart button and pray for the best. But why settle for guesswork when we can actually look under the hood? If you really want to get to the bottom of what caused the instability, you shouldn't just stare blankly at the blue screen. You need tools. I always recommend starting with BlueScreen View http://www.nirsoft.net/utils/blue_screen_view.html. It provides a decent high-level overview of which driver might have been the culprit. However, if you're looking for a bit more narrative—something that actually attempts to explain the "why" in plain English—WhoCrashed is an indispensable companion. It does a much better job of translating technical jargon into something a human being can actually digest. Does anyone else find themselves falling down these rabbit holes, or am I just uniquely obsessed with debugging my own frustration? If you've managed to pinpoint a specific driver causing your crashes, I’d be curious to hear your findings. Let's see if we can turn this chaos into some actual clarity.
The crash dump files can be located here: C:\Windows\Minidump
It appears that crash dumps have been successfully enabled on your machine.
It appears that no valid crash dumps could be located on your system.
In summary, what have we actually learned from this entire ordeal? After wading through the technical minutiae and the various diagnostic tools, one has to wonder if we are truly making progress or simply spinning our wheels in the sand. We have analyzed the logs, scrutinized the error reports, and attempted to pinpoint the exact moment the system faltered, yet the core issue remains as elusive as ever. Is it a hardware failure lurking in the shadows, or merely a software glitch dancing just out of reach? One can only hope that the following steps provide the clarity we so desperately seek.
The system indicates that while crash dump settings are technically enabled, no valid dump files have actually been generated. If you are currently dealing with frequent system crashes, it is highly probable that some underlying mechanism is actively preventing the OS from writing those critical dump files to the disk. Is there anything more frustrating than a crash without a trace? To get to the bottom of why your system might be blocking these files from being saved, I strongly suggest reviewing this technical breakdown regarding common causes for missing crash dumps: If crash dumps are not written out.
If you’re looking for some guidance on how to tackle these system crashes, I highly recommend heading over to the general troubleshooting thread. It contains a wealth of helpful suggestions that should get you started on the right foot.
Let’s be realistic: you can never say with absolute, hundred-percent certainty that a specific driver is the culprit behind your latest system crash, nor can you be sure if the real issue lies buried within some other obscure module. It’s often a guessing game. Nevertheless, wouldn't it be wise to proactively hunt down updates for the software associated with those drivers? Furthermore, I would strongly suggest making regular trips to Windows Update—or better yet, simply enabling automatic updates for Windows to save yourself the headache. If you suspect that a faulty piece of hardware is actually pulling the strings behind these failures, why not try a quick Google search? Tossing your specific bug check errors into the search bar along with your computer's brand and model might just provide the breakthrough you need to solve the mystery.
electricharbor30 As I have previously observed, there is a certain level of frustration when one is forced to deal with such technical inconsistencies. Does anyone else find themselves wondering why these issues persist despite our best efforts? It seems we are constantly circling back to the same fundamental problems.
The next time you find yourself staring at a BSOD, do me a favor: grab a pen and jot down that specific stop code displayed at the bottom of the screen—you know, the one starting with "0x" followed by a string of numbers. Once your computer is back up and running, just Google that exact code. You'll likely find plenty of discussions on various tech forums explaining exactly what went wrong and how to fix it.
I shall make sure to take notes next time.
53 messages
joined Feb 2016
I downloaded it and got it running, but there isn't a single scan option in sight. Everything just looks completely empty...
Here is a tutorial:
Just a heads-up: if those dump files get wiped out, you won't be able to read the error at all until the next crash occurs. So, the moment a BSOD hits again (fingers crossed it doesn't), run either this tool or that other one immediately. 🙂
joined Sep 2010
https://www.winhelp.us/analyze-crash...hocrashed.html
goldenviper13 said:I downloaded it and got it running, but there isn't a single scan option in sight. Everything just looks completely empty...
Here is a tutorial:
I went through the tutorial, but there is absolutely nothing in the Windows-Minidump folder. It’s completely empty.
When I powered it up today, I was hit with an error: "Loading system error. Insert system drive."
This actually used to happen a few days in a row back in the day, so I would check the HDD cables, reseat them, and everything would work fine... until now.
53 messages
joined Feb 2016
ambergull said:I went through the tutorial, but there is absolutely nothing in the Windows-Minidump folder. It’s completely empty.
It could be a driver issue with the DVD drive or a failing hard drive. Have you checked the BIOS to make sure the HDD is set as the primary boot device? If you have an installation disc handy, try running a system repair.
goldenviper13 said:It could be a driver issue with the DVD drive or a failing hard drive. Have you checked the BIOS to make sure the HDD is set as the primary boot device? If you have an installation disc handy, try running a system repair.
Yes, I have the HDD set as the first priority, followed by the DVD drive.
I have already attempted the repair process as well.
I shut the machine down yesterday, but when I powered it back up today, I was met with "Error loading operating system. Enter system drive..."
It required several hard resets and even pulling the plug from the wall before it finally decided to boot up again.
