Home › IT › Hardware › Desktops › PC parts build under $550
Started by driftingdrifter88 · · 👁 4 views · 5 replies
Participants driftingdrifter88Larry Ortiz5Adam Moore3Robert Rodriguez2
driftingdrifter88 driftingdrifter88 MemberOP
31 messages
joined Jan 2016
I'm looking to pick up
a motherboard
with an i9 proc
a GPU
an SSD
and some RAM
The total cost is somewhere in that ballpark... maybe a little higher depending on what I find
The rig would basically be for casual gaming and doing a bit of 3D rendering here and there
Are you buying a computer here in the States? Since you mentioned euros, I just had to ask 🙂
$500 for a gaming rig with an i7? You might want to check your math on that one... 😁 Does that include the case, power supply, and hard drive?
driftingdrifter88 said:I'm grabbing an
motherboard
CPU (i7)
GPU
SSD
RAM
The total is somewhere around there... maybe a bit more
It'll be enough for some casual gaming or light 3D work here and there...
Just the CPU alone is over $400 and you think you can get the whole rig for $500? Yeah, right.🙂
31 messages
joined Jan 2016
Robert Rodriguez2 said:The CPU alone is sitting at over $400, and you're trying to grab the whole setup for $500? That’s just wishful thinking... 🙂
I usually just pick stuff up locally... wait, looking back at my notes, I actually wrote down an i7. My mistake, I meant an i5.
If I already have a case and a power supply lying around, let's call the total budget maybe $650.
I don't need anything built for heavy lifting or high-end gaming.
At that point, I could probably just hit up Best Buy and grab some decent components centered around an i5 instead.
Honestly, I’d say you’ve got maybe a week before those new AMD cards hit the shelves... especially an RX 470, which would be a total waste of money for your budget 😁
