Home › IT › Hardware › Desktops › Power supply (dead?!)
Started by lonebear8 · · 👁 5 views · 2 replies
Participants lonebear8Benjamin King2darkbadger12
lonebear8 lonebear8 NewcomerOP
Hey,
So, my brother's PC just died on him one day—completely cut out. I checked back in about 30 minutes later to try and boot it up, but the second I hit the power button, there was this little flash behind the tower and a faint "thud"... plus that distinct smell of something being fried. No actual smoke or flames, though. 😁
I went ahead and pulled the power supply out since that’s my main suspect. It's open now, but honestly, I don't see anything obviously burnt... which doesn't help much. I'm pretty much a total novice when it comes to PC hardware—are there any specific telltale signs I should be looking for to figure out if it was just the PSU that bit the dust or if something else is toast?
Just borrow a power supply from somewhere else if you want to run some tests.
darkbadger12 darkbadger12 Newcomer
Stick your multimeter into the power supply—you’ll feel it immediately if you aren't careful about not frying the motherboard!!!
