Home › IT › IT Support › Troubleshooting 5.1 surround sound via audio receiver on PC
Started by darkmaker13 · · 👁 8 views · 4 replies
Participants darkmaker13Angela Flores4
darkmaker13 darkmaker13 NewcomerOP
So, here’s the deal—I used to have two HDMI ports on my GPU, so I’d just plug my monitor into one and my audio receiver into the other, and everything worked perfectly. Now, I’m stuck with just one HDMI port for my monitor (the rest are DP 1.4 and DVI), and suddenly there's zero sound. Here's the kicker: I’ve got an HDMI port on the motherboard too, but neither the video nor the audio is working through it. How can I get both running at the same time—ideally keeping things on HDMI? Drivers are all updated and good to go...
The MB is an ASUS ROG Strix B450-F Gaming
Angela Flores4 Angela Flores4 Active Member
85 messages
Look, if you actually have an AV receiver sitting there, the simplest fix is just to run both your PC and your monitor through it using HDMI cables. Alternatively, you could link the receiver directly to your graphics card via HDMI and then plug your monitor into the card using a DVI or DisplayPort connection instead. Once you dive into your sound settings and tell the system to route the audio through the GPU, everything should theoretically fall into place without any drama. :coffee:
Of course, if you’re looking for a third option, you could always just go out and buy a second graphics card or pick up a dedicated multi-channel sound card.
Bradley Lewis59 said:Look, if you’ve got an AV receiver, just run HDMI cables from your PC and monitor straight into the receiver. Or, you could hook the receiver to your GPU via HDMI and then plug the monitor in using DVI or DisplayPort. Just make sure you tweak your settings so the audio is routing through the graphics card—that should do the trick. ☕
The third option, obviously, is just grabbing a second GPU or a multi-channel sound card.
I'm gonna try hooking the receiver to the GPU via HDMI, then I'll run the monitor off the GPU using DVI-D since they share the same slot. Should be fine, right? My only real question is what's the point of that HDMI port on the motherboard if I can't get any audio out of it.
Fixed it using an HDMI to DVI cable.
85 messages
The HDMI port on your motherboard is tied directly to the integrated graphics. You'll likely need to dive into your BIOS first just to enable it—unless, of course, you're unsure if your PCI card and integrated graphics can even play nice together at the same time—and once that's sorted, you'll have to head into your audio settings to actually route the sound through it.
