Home › IT › Hardware › Computer Peripherals › TV tuner card or HDTV monitor?
Started by wiredheron94 · · 👁 6 views · 4 replies
Participants wiredheron94Kyle Davis6wanderingpanther68Joshua Garcia3
wiredheron94 wiredheron94 NewcomerOP
joined Jan 2013
I'm looking to pick up a 23-24 inch monitor—budget is around $500 though I don't mind dropping more if the quality actually justifies the hit to my wallet.
Since this is basically going to be my main screen—or what my grandma would probably just call a "television"—I'll be using it for movies and stuff too. So, I'm wondering if it makes more sense to grab a monitor with a built-in tuner or just go the TV tuner card route.
I’d love some advice here—specifically, what are the pros and cons of a monitor with a tuner versus using a card? Also, if you have specific models in mind for either setup, please let me know.
Kyle Davis6 Kyle Davis6 Newcomer
joined Oct 2012
It really just comes down to what works best for your specific setup.
If you’re looking to avoid cluttering your desk with extra gear, grabbing a monitor with a built-in tuner is probably the easiest way to go. But, if your plan is to record shows directly onto your hard drive or manage video playback through your PC, then sticking to a standard monitor paired with a TV tuner card makes more sense. It’s all about how you want to use the space...
For instance, if you go the tuner card route, you can watch TV right there on your screen while you're working on the computer, whereas a standalone monitor with a tuner might be a bit of a hassle to switch back and forth when you're mid-task! 🙂 (I know, I'm making this sound way more complicated than it actually is) ☕
wanderingpanther68 wanderingpanther68 Active Member
I don't want to clutter things up by starting a whole new thread...
I managed to get my hands on this Group of 22'' LCD TV monitor
so I was wondering, even though it’s technically a TV, can I just sit there and stare at it all day from close range like any other standard LCD computer monitor?😁
I realize how kind of a silly question this sounds... xD
It’s basically just a standard monitor that happens to have a built-in digital TV tuner, so there's really nothing to worry about.
I suppose I should have seen this coming, though I can’t say I’m particularly surprised by how quickly things have spiraled. It feels like we’re all just circling the drain now, isn't it? I’ve been sitting here trying to make sense of the latest developments, attempting to find some shred of logic in the chaos, but honestly, it’s a bit of a losing battle. One moment you think you've finally grasped the underlying pattern, and the next, everything just shifts under your feet again, leaving you feeling slightly foolish for ever having felt confident. It’s a bit exhausting, really, if I'm being completely honest with myself. kaže:
Look, don't sweat it—it’s essentially just a standard computer monitor that happens to have a built-in digital TV tuner tacked on, so there's really nothing to worry about.
Thanks so much! 😉
