Home › IT › IT Support › Why is my home Wi-Fi speed so much slower on mobile?
Started by Bradley Clark90 · · 👁 5 views · 4 replies
Participants Bradley Clark90shadowlynx102wearymason4darkcyclist92
Bradley Clark90 Bradley Clark90 NewcomerOP
Hey everyone.
I’ve been digging into this for a while now and I can't figure out where the bottleneck is, so I figured I’d ask for some input here.
The issue is that when I connect two different phones to my home Wi-Fi, the speeds are drastically different. My internet plan is roughly 50Mbps. On my laptop, Ookla shows 50Mbps, which is fine; on my iPhone SE, I also get 50Mbps, but on my iPhone 12, it drops down to about 8Mbps. When I visit my brother's place where he uses fiber, his iPhone SE hits 245Mbps, yet his iPhone 12 only manages 20Mbps.
What am I missing here?
shadowlynx102 shadowlynx102 Active Member
91 messages
The issue clearly stems from the iPhone 12 itself, whether it’s tied to specific software settings or some kind of hardware limitation.
Yeah, looks like it's stuck on a fixed 802.11g setting instead of being set to auto-select, even though it’s got dual-band support for 802.11a,b,g,n,ac.
darkcyclist92 darkcyclist92 Active Member
66 messages
It is honestly exhausting having to revisit this topic again, but here I am dealing with my iPhone 11 and the constant, infuriating inability to connect to public Wi-Fi networks that require those annoying captive portal authorizations. I’m talking about places like Shell stations, local bars, and various other spots where you just expect things to work effortlessly.
I have been led to believe the culprit is a static MAC address causing the handshake to fail?
wearymason4 said:Yeah, looks like it's locked into 802.11g mode instead of using auto-select, even though it’s a dual-band setup supporting 802.11a, b, g, n, and ac.
Is there a way for me to verify this and switch it back to auto-select?
