Home › IT › IT Support › Wireless connection issues
Started by analogwalker2 · · 👁 4 views · 1 reply
Participants analogwalker2Larry Ortiz5
analogwalker2 analogwalker2 Active MemberOP
76 messages
Hey there...
So, I just went ahead and did a fresh reinstall of Windows 7
And now I’m running into this one specific headache—something I definitely didn't deal with before the reinstall—and for some reason, I just can't seem to pin down what's causing it.
Every single time I boot up my computer, the wireless is somehow stuck in the "on" position—meaning it's enabled—even though I specifically made sure to click disable right before I shut everything down.
I’m honestly at a bit of a loss here; does anyone know where in the settings I can actually fix this?
To reiterate: prior to this whole Windows reinstall, the wireless would stay exactly how I left it when I turned the machine off. It was seamless! Now, it's like the system refuses to remember my preference.
Are we talking about a desktop or maybe a laptop? And just to be sure—are you trying to get those Wi-Fi drivers installed?
