Home › Lifestyle › Health › Need help interpreting these lab results
Started by Megan Wilson27 · · 👁 4 views · 3 replies
Participants Megan Wilson27Angela Lopez90
Megan Wilson27 Megan Wilson27 NewcomerOP
joined Mar 2007
I need some help deciphering this: What exactly does a partial ACL tear, an intrasubstance rupture of the posterior horn of the medial meniscus, and joint effusion actually mean?
Please help if anyone knows what I'm looking at.
Angela Lopez90 Angela Lopez90 Newcomer
Megan Wilson27 said:I need some help deciphering this: partial ACL tear, intrasubstance rupture of the posterior horn of the medial meniscus, and joint effusion.
Please help if anyone knows what this means.
Basically, the ACL and PCL are the main ligaments holding your knee together from the inside. In your case, the ACL is partially torn.
The cartilage surfaces between your knee bones are cushioned by the meniscus (medial and lateral). Each meniscus has two parts—a front and back horn. You’ve got a tear in the back horn of the medial meniscus that goes into the tissue itself rather than out toward the side. As for the "joint effusion"—that's just medical speak for swelling.
Hope that clears things up.
If you happen to be young and an athlete, look at it this way—Serena Williams had to go under the knife for stuff like this at least three times.
joined Mar 2007
Thanks! I'm going to have to undergo surgery, though I'm still not sure when. Hopefully, I'll pull through. 🙂
I’d highly recommend the local hospital in Carmel-by-the-Sea.
