Home › IT › Hardware › Desktops › Where's the best place to find these parts for cheap?
Started by Robin Young7 · · 👁 5 views · 8 replies
Participants Robin Young7Sean Garcia3crimsonstag84fadedorca66Kimberly Gomez34
Robin Young7 Robin Young7 NewcomerOP
joined Jan 2015
http://www.pc-specs.com/pc-custom-builds/1108285
I put together a build on this link. Since I already have some parts, where's the best place to hunt for deals on the rest?
I've already got the Intel, the hard drive, the motherboard, and the case. 😁
So, I just need to upgrade my RAM, the graphics card, and the power supply...
Sean Garcia3 Sean Garcia3 Newcomer
joined Jan 2015
1 x AMD Radeon R9 270
1 x Fortron 500W Power Supply, Hyper, PPA5005003, 12cm fan
1 x DDR3 8GB (1x8GB) Kingston Fury, 1866MHz, CL10
Total:$840 Micro Center free shipping!
If you don't have a decent cooler, you seriously need to grab at least this one unless you’re looking to overclock because that stock cooler that comes with the processor is garbage—it'll be loud as hell and your CPU will just overheat.
joined Jan 2015
Sean Garcia3 said:1 x AMD Radeon R9 270
Great.
Thanks for the heads up!!
I’d probably lean toward this setup instead. I think you get a better Intel chip for less money, plus the graphics card is basically the same and the cooler seems a bit more solid. Oh, and the power supply is a huge step up.
AMD Radeon R9 270, 2GB GDDR5
Transcend MEM DDR3L 8GB 1600MHz TS
EVGA SuperNOVA 450W
Raijintek CPU Cooler BlackRock - 92mm
Total: $842(+$13 shipping) Best Buy
joined Jan 2015
crimsonstag84 said:I’d probably lean toward this setup instead. I think you get a better Intel chip for less money, plus the graphics card is basically the same and the cooler seems a bit more solid. Oh, and the power supply is a huge step up.
EVGA SuperNOVA 450W
Oh, and heads up—the PSU in the link is wrong. I'm actually running a Corsair CV450.
You couldn't possibly have meant putting a $33 in a rig with high-end parts like this, right?
joined Jan 2015
Robin Young7 said:Oh, and heads up—the PSU in the link is wrong. I'm actually running a Corsair CV450.
We figured the power supply was junk right away, so we swapped it out for better, higher-quality units that come with a 5-year warranty. We also went with a single 8GB stick of RAM instead of two 4GB sticks. Since that motherboard only has two slots, using one stick leaves you an open slot for an upgrade later on; if you use both 4GB sticks now, you're basically maxed out. Besides, whether it's one stick or two doesn't really make a difference anyway.
So basically, you DON'T HAVE a power supply.😁
joined Jan 2015
Sean Garcia3 said:We figured the power supply was junk right away, so we swapped it out for better, higher-quality units that come with a 5-year warranty. We also went with a single 8GB stick of RAM instead of two 4GB sticks. Since that motherboard only has two slots, using one stick leaves you an open slot for an upgrade later on; if you use both 4GB sticks now, you're basically maxed out. Besides, whether it's one stick or two doesn't really make a difference anyway.
Thanks for the tip on the RAM. As for the power supply, I had no clue if it was garbage or not, which is why I mentioned mine was different. You guys clearly know your stuff better than I do—I don't really dive into all the technical details—but thanks again!🙏🙏🙏
